90-93 TOTAL POLY KIT (W/ RR UPR C-ARM BUSHINGS)
Production vehicles are built using rubber bushings in control arms, strut arms, motor mounts, transmission mounts, sway bars and shocks. Not only are rubber components on the soft side, they also tend to deteriorate rapidly. This contributes to premature component failure, a "spongy" ride and less than ideal performance handling. Urethane's stiffness and durability can correct these conditions, while improving drivability.
Kit Includes:
Ball joint boots, front and rear control arm bushings, shock bushings, strut arm/rod bushings, sway bar bushings, sway bar end links, tie rod boots and rear upper control arm bushings.
Would this kit be a good idea since I'm going to do all of this suspension work anyway? What else would I have to replace?
Kit Includes:
