Advice on removing Rack and Pinion Boot
    I got to replace my inner tie rod. How do you remove the boot. My boot is rip so i got inner rod out already. Just need to figure out how to get the rest of the boot out.
    any tip?
    any tip?
    The boot? Cut the clamp and pull it out...
      how do you get the cutter in there no room
        I have done it multiple times... It may be a little tight but it is defiantly possible.
        If you do not have enough room to cut the clamp you will not have enough to install the new boot.
