I have over the last two weeks replaced upper balls, lower balls and tie rod ends and wheel bearings and intermediate shaft and bearing. Every thing I have put on has made the shake tighter, more violent. I used to cruise at 70 with a soft slight shake, now I cruise at 55-60 feeling like I need to pull over. I have not had it aligned yet, (tie rod ends) because I think its something else maybe. My car does not pull now nor did it before I started. That being said here is my list of up next.
1.alignment (tired of throwing parts at it)
2.new hubs and rotors sucks cause I just put bearings in.
3.rack and pinion.
4.bushings (they aren't that old and are neoprene).
5.wheels and tires its last cause Iike stock wheels and its hard to find 16 inch from a 2.3 cl at the junk yard.
At 330,000 miles I probly need this whole list but would love to hear how someone has solved their shakes. Maybe I need to change the order of attack.
3.rack and pinion.
