Hey all, I'm Chris/Beans/Chrisnick. Picked up this '97 CD7 LX in March 2013, have been DD'ing it/getting it back into shape and autocrossing with the SCCA. PO was a filth monger and didn't take great care of it, and I've done a TON to get the car back into shape. Car looked pretty clean, and aside from the trunklid rust, I *thought* it was very solid. STC-ish focused build for '13 and '14, but not 100% to the extent of the rules and I chose the mods to maintain a decent drive for day to day. Slowly turned into moving towards FSP in '15, and will probably be proceeding into SMF beyond '15 as I hunt for more power and less weight. I'm fairly certain I can get to my target HP/TQ goal without having to do a swap or boosting the car with carefully selected parts. Much more than 200whp/tq for a FWD is overkill and requires big money invested into R-compounds and other supporting mods.
Best timeslip as of 08/20/15
Mods currently:
Prelude H23 eBay Intake tube
Blox aluminum velocity stack
AEM 6" dryflow filter
Rotor over hub conversion, Prelude VTEC rotors, ITR/V6 calipers up front, 25T brackets
Hawk HP Plus front brake pads
JVT "long tube" 4-2-1 header
2.5" exhaust, vibrant ultra quiet resonator and stealth muffler
Timmytuning F23A1 chip/map/tune on a P28+ OBD2A to OBD1 jumper
F23A1 Swap
BB4 M2F4 with syncrotech carbon second gear synchro
F23A1 intake manifold, ported, shorter runners, 62mm TB port-matched upper
Bisimoto intake manifold gasket
62mm H23A VTEC throttle body
thermal TB gasket
IAT sensor moved to intake piping
DX cruise control delete: steering wheel and dash plate, cruise deleted.
Bilstein HD Shocks
Front eBay coilover sleeves with 550lb, 7.25" springs, hyperco tenders
Rear all star performance 7" sleeves/collars, summit 450lb(left) 400lb(right) 9" tall 2.5" diameter springs
Energy Suspension front upper and lower shock bushings
Energy Suspension 2.5" spring isolators
Progress 22mm rear sway bar
NO front sway bar
Neuspeed upper shock tower brace
DA Upper control arms
Prothane Rear engine mount insert
Energy Suspension Front engine mount insert
Energy Suspension front radius rod bushings
Skunk2 5-speed dark grey shift knob
4th gen Prelude shifter, K-tunes transmission bushings, FFC shifter bushings
15" 6 spoke 98-02 Accord wheels 195/65/15 General altimax Arctic(winter)
94-95 Grill
97-99 Acura CL mirrors
"E46 M3" style rear lip spoiler
DIY blackhousing headlights
Gloss black Kylron Fusion painted mouldings, front lip, side skirts
Mods currently:
F23A1 Swap
thermal TB gasket
Bilstein HD Shocks
NO front sway bar
94-95 Grill
