i hooked up my amp and when turn on the music i can hear static noises. im guessing i have a certain wire hooked up wrong. i'm not sure... any other possible way to to cause this noise?
static noise in speakers.
If the static is coming from the speakers I would look for bad speaker connections either at the amp or the back of the deck. You should even consider the RCA's as well, could be bad. A bad amp ground will cause the amp to shut off and on during high power draw or turning, not static.Originally posted by Mishakol129Do not disrespect my intelligence. I am the smartest person I know : )
Originally posted by AbsurdNY View PostWhen you ran the wires for the amp, were you sure that you did not run the rca's next to the power wire?Originally posted by Mishakol129Do not disrespect my intelligence. I am the smartest person I know : )
