Idle between neutral and 1st and powersteering
    I just bought a 1992 Honda accord 5spd. They car runs great, but when the car is in first gear and I haven't engaged the clutch just yet, it seems to idle really low. It's almost like it wants to die. It doesn't die, but the car shakes a little because it's idling low. Is there anything I can do to stop the car from doing this? Also, my car doesn't have power steering. Is there a way to put power steering in my car? Thanks.
    -Cy
    Just search through existing threads. There's information pertaining to your situation already. In terms of power steering, unless you parallel park a lot, I wouldn't say it'd be worth it. That'd be just straight up stressful.
    In terms of the idle issue, could be the IACV, FITV, a vac leak, your idle speed could be set a little too low.
    life is good.
      look at your steering rack and see if any of the lines for the power steering was altered. if they are still there, it is only a matter of hooking the pump and belt up. Im pretty sure all accords came with power steering because there was no manual steering rack offered.
      there is a power steering input to the ecm which can alter the idle and this is controlled by the IACV. i get a low dip sometimes when im using the powersteering and hitting the brakes in a parking lot.
      I <3 G60.
