Old 11-05-2018, 10:02 AM   #1
CB9_IS_2_BETTER
CB9_IS_2_BETTER is cool... so far.
H22 swap exhaust
I am curious about exhaust diameters after doing an h swap. Does using the same smaller diameter accord exhaust (I believe 2") create too much backpressure for the new engine? I am replacing my exhaust regardless and would like to get whatever will be ideal for a stock h22a. Thanks
CB9_IS_2_BETTER is offline   Reply With Quote
Old 11-05-2018, 10:05 AM   #2
sonikaccord
2.5" should be good enough for a stock, healthy H22A.
2" is on the small end for that engine, imo.
Old 11-05-2018, 10:45 AM   #3
CB9_IS_2_BETTER
Thanks, I know very little about exhaust systems and all help is appreciated. I will measure my exhaust after work to find out for sure, but do you have any opinions on just buying a catback setup vs taking it to an exhaust shop. I see some reasonably priced catback systems online but I don't know about quality, I also don't have a cat in my car currently, just a crappy muffler the rest is straight piped. I want to put in whatever will be best for my car. Thanks
Old 11-05-2018, 09:47 PM   #4
CB9_IS_2_BETTER
Looks like I am actually at 2.25 right now, would it still be advantageous for me to go up to 2.5?
Old 11-05-2018, 09:53 PM   #5
deevergote
Don't call me dude.
Install a cat.
Otherwise, 2.25” or 2.5” is fine. Narrower will give you a bit more power down low, and cost you a bit up high. Since most of your diving will in the lower RPM range, you’ll probably get more use from 2.25”. If it sounds good, that’s all that really matters. Many Japanese exhaust systems, and probably the cheap knockoff copies, are 60mm... which is roughly 2.36”.
If you like it loud, get a small can and no resonators. If you want it quiet, run a big can and the longest resonators you can fit.
But seriously, install a cat.
Old 11-06-2018, 02:37 PM   #6
CB9_IS_2_BETTER
Ok thanks, I will probably keep it at 2.25 or 60 mils then for lower end power, but I was planning on putting a cat in with the new system. My exhaust fell off a while ago and all I could afford was the cheapest they could do, it's time to fix that. I want it to be on the quiet side but sound decent so I will probably be looking for a decent sized resonator. Thanks again
Old 11-08-2018, 07:38 PM   #7
CB9_IS_2_BETTER
Do you guys know if the cat flanges are the same for the F and H? I am looking at possibly getting a catback and buying a cat then taking it to a weld shop. I think I will have to find a downpipe at a junkyard to get the engine side flange for the cat, but am just curious if it is the same for prelude and accord.
Old 11-08-2018, 08:11 PM   #8
deevergote
Don't call me dude.
They should be.
Old 11-09-2018, 03:36 PM   #9
CB9_IS_2_BETTER
Ok thanks, I might just end up getting a new downpipe and a catback then just buy a cat and bolt it all together, but I have read a few things about the fitment of aftermarket catbacks on the wagons so I am hesitant.
Old 11-09-2018, 06:39 PM   #10
deevergote
Don't call me dude.
Yeah, the wagon fitment is different. You can modify a sedan/coupe exhaust, or better yet, just have a reputable shop build you something. I went that route, and never regretted it.
Might as well just buy a complete header. Megan Racing and OBX make decent ones for reasonable prices.
Old 11-10-2018, 01:22 AM   #11
CB9_IS_2_BETTER
Yea I know someone who welds exhausts on the side, I was still looking online to see which should be cheaper, I don't have a ton of money to throw on this but hate my current setup and anything will be better. I am also really indecisive and still deciding between 2.25 and 2.5 haha
Old 11-10-2018, 08:11 AM   #12
sonikaccord
Get whatever is cheaper. Budget first.
Old 11-10-2018, 02:56 PM   #13
Corweena
Corweena is cool... so far.
Since you have a wagon, I'd definitely recommend going with a custom setup. Get your cat, and a good resonator and whatever muffler you decide you want to run, and a nice exhaust tip. Take it all to an exhaust shop and have them cut/bend/weld a custom setup for your wagon. Easiest way to go about it, and will be probably be a good amount cheaper than buying a quality catback for a coupe/sedan and then have to chop it up to fit.
You could even play with getting a larger collector for your header downpipe....most of the bolt on ones Like Megan or OBX only have stock H22 size collector or a just a tad bigger. You could jump up to a 2.5 collector, then run a 2.5" cat and piping all the way back. Will open up the flow for if you want to make more power down the road. You are already doing the work, may as well add a bit more now, and not have to touch it in the future.
Corweena is offline   Reply With Quote
Old 11-11-2018, 10:16 AM   #14
CB9_IS_2_BETTER
Thanks a lot, I do plan on doing more building in the future so that might be a good idea to go 2.5 now. Get it all done at once. And the collector is the length of downpipe after all the pipes merge together correct? Also, any mufflers or resonators you would reccomend? I currently only have a really crappy muffler and nothing else so I’m coming in pretty much from scratch. Thanks
Old 11-12-2018, 04:09 PM   #15
deevergote
Don't call me dude.
That’s correct on the collector. You can find decent collectors from Burns Stainless. Not cheap, but very well made. You might also want to consider a higher quality header, like DC Sports. Adding a new merge collector isn’t cheap, so it’s a better idea to do it to a header that is going to last longer than the brands I mentioned. It’s a worthwhile mod, though.
Resonators, just get the proper length. Longest you can fit. Brand doesn’t matter that much.
Muffler, it depends on what you’re going for. A nice fat can like the Apexi World Sport will be quiet and look pretty cool. Personally, I had a generic dual tip muffler that my muffler shop had on hand. No idea what brand it was, but it sounded great. Loud, though. The bigger the can, the quieter it will be.
Cat, buy OEM style. No high-flow, no “racing”. Buy quality, so it’ll last. The originals tended to last 20+ years.
Old 11-13-2018, 11:51 AM   #16
Corweena
Even DC Sports have quality issues sadly. A log of times they will crack where the primaries meet and go from 4 to 2. Greddy would be the better choice, but is MUCH more rare and hard to find now.
Another route (which I went) is to get a Japanese JASMA Spec header for the H. These are much better than most of the bolt on ones available in the US. They actually have a 60mm collector (2.36"). Not quite 2.5, but definitely a nice upgrade over most. Plus they are bolt on, and fit 100%. The Popular brands are FGK, Mugen, and Limit A/X (Tanabe). Quality on these is top notch as well. Prices vary....I picked up my FGK for $130, but I've seen them listed for $350 as well.
There are also some more "performance" header options you can buy new. They will actually make good power, but are not the best quality, and you generally have to modify your subframe to clear the tubes. Look up High End, PLM, 1320, etc.
Lost of different options, just depends on how much you want to spend and how much work you want to do.
Old 11-16-2018, 01:51 PM   #17
CB9_IS_2_BETTER
Thanks you guys, so I was planning on sticking with my stock header but it is interesting that the JASMA downpipes come out at 60 mils might be worth it to look into one of those. It would also be easier for me as I don't currently have the flange at the end of my downpipe its just all welded up, so that would be nice to get too. And I want it quieter so I will go with a good size muffler but I probably wont splurge on the world sport haha
Old 11-16-2018, 07:28 PM   #18
deevergote
Don't call me dude.
Just be sure to find a true Japanese header (JASMA is kinda like their equivalent to our CARB). There is a cheap crap “JASMA” brand out there that’s basically just overpriced generic garbage.
We’re getting into some money, though. Throw $500 at a muffler shop for something decent. $600 if you pick a good muffler up on your own. The rest of the stuff we’re discussing here could easily top $2000 by the time you’re done! unless you shop smart for a killer deal. They happen.
exhaust , h22
