EXT : Legend lip install.... 56k be warned!!!
    so the problem is that the holes dont line up for the screws?
    im going to get the coupe lip so im trying to figure out how to do this right
    i have the oem lip so does that make it any easier ?
    PSN: DJ-dlatino
    My ride
    http://www.cb7tuner.com/vbb/showthread.php?t=140370
      no you still have to cut and drill man it is mad ez
      back at it again
        nice diy with photos *claps* preciate it!!
        Originally posted by Juice21
        thnx pimpette, your car inspired me to go lower
        Originally posted by GameChewer
        Shiit i heard that, you heard the queen!
          your welcome lol
          back at it again
            i just did this using all stock hardware, no extra bolts and washers and screws.
            with the sedan lip no less!
            A really good blade cutter and some ingenuity
            let me know, and I'll tell ya how
            1992 Accord EX MT : CB#2
            DIY OEM amber corners w/reflectors
              ooh rly cool man just post it up on here lol
              back at it again
                just got the lip for cheap, thanks for the DIY.
                does anyone else think that this look better on 90-91's? the dip in the middle doesnt flow with the 92-93 lines.
                I <3 G60.
                  ftw nice diy
                    so the front curve is the same but not thes sides that the only palce you have to mod
                    and where is my best bet for one of these in canada
                      to find/get one go to the junkyard/salvage yards lol
                      yeah the spot in the middle you'll need to trim
                      back at it again
                        ^^^ the only trimming i did on the lip was really on just the tabs and a little bit in the middle part to let it mold into the original bumper.
                        maybe i will
                          maybe i will
                          just reserve some spots on the install thread lol and put the page # at the beging
                          back at it again
                            6 bolts (a 3/8in. or 1/4in. bolts will work fine.)
                            12 washers for the bolts
                            10-12 screws preferably 1/2in long (i used sheet rock screws but sheetmetal screws will work too.)
                            So where am I supposed to screw and bolt all these too?? I dont see how you can use that many bolts and screws. I put the stock hardware on the tabs near the middle, but im not really sure if I need to go ahead and add a bolt with those. How many bolts/screws did you guys use? Is 3 or 4 on each side enough?
                            Formerly know as accord-racing Jan 06 - Dec 07
                            BOUGHT FROM: cb95spd, lildeez07, L3G10N, JARHEAD293, True-BlueCB7, Boost_Lee, djcaz_aom, zmiennik
                            SOLD TO: treyd82, Sneakerhead28, BoxMan, civic_90_08, greenmachine9, baracuda, zmiennik
                              i only used 7 screws when i had a 91-93 legend lip
                              one on each end, then another at the corner, and another towards the middle.
                              May have put a few more screws towards the end.
                              I guess you can never be too secure lol.
                                Alright thanks, im going to add one to middle where I put the stock hardware and put one bolt on th tab inbetween there and the end then have 2 bolts holding it at each ends. I just sliced my finger with a razor trying to cut one of the tabs lol I almost passed out and it wasnt even bleeding but I know it was pretty deep cause I had alot of pressure on the blade.
