I have a 92 accord ex coupe. 15 inch rims. Will a full size rim and tire fit in trunk where the half size spare is ? If not then how much of it would bulge out?
Will full size spare fit in same place as half wheel
It will fit diameter wise, but will protrude about 1.5 inches above the rest of the floor. In an LX coupe or sedan, a wagon trunk compartment will fit with a little modification to give a flat floor over a full size spare. Before I put one in Ruby (90LX), I used some pieces of 1.5 inch thick insulation board to raise the floor around the spare.
The ABS control box on the right side of the trunk in the EX intrudes more, so installing a wagon floor would involve a lot more cutting. I looked at it for my 92 EX coupe, but couldn't bring myself to butcher the wagon trunk compartment or the trunk liners in the car.
Edit: I suppose one could 3D print side compartments that would match the available space.Last edited by Fleetw00d; 04-23-2017, 11:33 PM.90 LX 4dr 5 spd 396,014 (sold 1/1/2022) - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=201450
A full size spare does indeed bulge out a bit. But if it is a must, I suggest a wagon trunk compartment also. They bulge out themselves so you do lose vertical space, but you do have a rigid "floor" in the trunk. Plus, you get 2 panels that open that helps with organization.
Members' Ride Thread :http://www.cb7tuner.com/vbb/showthre...82#post2939682
My CB7 Tribute Vid..https://www.youtube.com/watch?v=XqWFstSzLH8
Track ready EK..https://www.youtube.com/watch?v=IoYKsoL0i7M
ok cool good to know. that floor in fleetwoods looks good. I never liked half spares. What good is a 25 yr old spare also. And if i am more than 70 miles away from home i do not want to drive on that little thing. Not sure if i want to butcher things up to make a wagon floor fit. Will have to see for myself i guess how much it bulges out.
Originally posted by fleetw00d View PostIt will fit diameter wise, but will protrude about 1.5 inches above the rest of the floor. In an LX coupe or sedan, a wagon trunk compartment will fit with a little modification to give a flat floor over a full size spare. Before I put one in Ruby (90LX), I used some pieces of 1.5 inch thick insulation board to raise the floor around the spare.
I too will soon have a wagon compartment floorsboards but i have a question for you.
In Ruby, are those the original side paneling in the trunk? My white 93 lx comes with blue somewhat fuzzy material on the paneling. Did u do something to your paneling to get a nice smooth look to themLast edited by ca93accord; 04-23-2017, 11:06 PM.
In Ruby, are those the original side paneling in the trunk? My white 93 lx comes with blue somewhat fuzzy material on the paneling. Did u do something to your paneling to get a nice smooth look to themLast edited by Fleetw00d; 04-23-2017, 11:32 PM.90 LX 4dr 5 spd 396,014 (sold 1/1/2022) - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=201450
