Misfire issue - ignition timing?
    Does anyone know what the stock timing is set at? I got a F20A DOHC and my timing is set to -16 degrees and it misfires really bad at idle. What should the timing be set at?
    You have been defeated by a car with child locks, how embarassing...
    "I noticed my f22 felt "healthier" until it blew up." <Myk>
    i believe 15 is correct.
    however one point shouldnt be making the car misfire.
    I <3 G60.
      firing order correct?
        yo Alex did you ever fix your car....
        the bad idle and misfiring because it sounds like my problem except I cant rev over 5000
        Mr. $3 Dollahz Himself!
          check your wires, firing order is 1-3-4-2
          -95 JDM H22 LSD-
          -HYTECH Header-
          -Skunk2 IM-
            ok I have this much....
            looking at the distributor from the passenger side, starting with the bottom plug going in a clockwise direction 2,1,3,4 is that what you have....
