Hi
I have tried to search for the answer but could not find it.
My axle is clicking when I turn left, this means my right Axle is the issue.
More often than not it is the outer bearings that click and therefore need to replace the outer bearing.
I have an automatic, sedan with original motor (F22A9) and transmission.
My questions and options are:
1) Using a complete CD accord axles.
I believe they are not interchangeable but please confirm.
2) Failing 1 above, my option is to repair my existing Axle.
Is the outer bearings on the CD Accords axles the same?
3) Failing 1 & 2 above my option is to use non ABS outer bearing and convert it to ABS.
Are the ABS rings removal? If yes, good success rate without snapping?
Any input would be appreciated.
