Hey guys hope everyone is staying safe!! I'm thinking of throwing my car on the dyno for a simple baseline tune. Nothing crazy. But before I go, what parts are recommended? As of right now everything is stock minus a cold air intake. It's a h23a1block and internals with h22 p13 head with accord 5spd. Thank you for your input everyone!! Btw, if you're going to ask why? Is because anytime after 5k, the motor sounds and feels "flat". If this makes any sense.. The motor has just under 8k miles on the rebuild.
Dyno prep
Originally posted by '93CB7Ex View Postbig tube header/exhaust, euro r intake
Falling flat after 5k makes me think vtec isn't engaging.
What engine management are you using? If you don't have something tunable, the dyno will be pointless. I would suggest calling the shop and asking what their tuner prefers to use, unless you're bringing your own expert.
You'll want a wideband o2 sensor at the very least.
Originally posted by deevergote View PostFalling flat after 5k makes me think vtec isn't engaging.
Originally posted by Rilas View PostYou can get a harness from Rywire, I'm not sure about Motec. There should be 2 wires going into the ecu, and 1 wire going to ground. There are multiple write ups on the forums. Just take some time to search them with google. You'll get much better results.
Originally posted by deevergote View PostThat would be a good idea. Getting a p13 might be good as well. Not totally correct, as there is no such thing for what you have, but as close as you'll be able to get. Troubleshooting an engine with a chipped ecu only adds to the headache.
