Go Back   CB7Tuner Forums > Parts & Performance > Appearance > Lighting
Old 05-13-2019, 04:42 PM   #1
Accord07
CB7tuner Member
Accord07 is cool... so far.
Best way to change headlight - low beams
Hello !
It's been more than 10 years since I changed bulbs on a CB7
I can't unlock the ring on the low beams. Without that I can't get the bulb out. Anyone faced a similar issue ? What was the best option or method on opening it ? Thinking about tapping it with a hammer and a flathead but not trying to break it.
Any help would be appreciated !
Accord07 is offline   Reply With Quote
Old 05-13-2019, 05:26 PM   #2
Raf99
Gold Member
I would do the hammer and screw driver trick. Tap it one way a few times, then the other way, then back the other way. Little light taps, see if you can loosen it up. Besides that, wear gloves + two hands, and lots of strength.
Old 05-13-2019, 06:16 PM   #3
cp[mike]
ŻŻŻŻŻŻŻŻŻŻŻŻŻŻ
cp[mike] is very helpful cp[mike] is very helpful cp[mike] is very helpful
I've had great luck with the hammer and screwdriver trick.
Some lubricating spray would also help - LiquidWrench and PBblaster both should be safe on plastic/rubber.
__________________
cp[mike] is offline   Reply With Quote
Old 05-14-2019, 12:19 AM   #4
Accord07
CB7tuner Member
Re
Yeah I'll give it a shot tomorrow. It's poorly designed in that sense
Old 05-20-2019, 08:12 AM   #5
Accord07
CB7tuner Member
Re
No go. It's just too dang tight. I can make it budge what's so ever.
Anyone have any luck ? Or any method ? I may take a zip tie and tug on the bottom
