2 DR DS Window information
    I finally bought my CB7 last night!!
    The DS window doesn't roll down, the handle just spins. I took the door panel off and took all of the parts out and the little gear isn't attached to the shaft that the handle attaches to so I guess I need the whole assembly.
    The window is also missing the sliding keeper thing.
    Does anyone know the technical names for these two parts?
    That is exactly why pork chops don't taste like chocolate!
    I'm confused as to what exactly isn't working for you. Can you take pictures and post them up?
      The window will not go up or down. When I grab a hold of the window crank handle and turn it, nothing happens. The crank handle itself is not stripped, and neither is the metal shaft that the the handle snaps on to. There is a small gear attached to that shaft that turns the big gear that raises and lowers the window, I need the name of that whole assembly that sits inside of the door.
      Unfortunately it started raining here, so I had to put everything back together quickly and did not take any pictures while it was out. I will take a picture of the missing window "keeper thing".
        it's a window regulator.
        http://www.hondaautomotiveparts.com/...ry5=DOOR+GLASS
        You can try the salvage yards and pray you get one that works or you could order one from Rockauto, they seem to have decent prices on them. I think there is even a discount code for them in the beginner's offtopic section.
          you might be able to find one in the j yard.note the 4dr ones do not work on the coupe.
          my new turbo build
            Piece that is missing.
            And one of the car.
              It's probably #1 in the diagram i showed you above.
                what does it do ? my glass does not have that .
                this was put together by evil_demon_01 . You can also fined all this and more by him in the Common Beginner Technical Info can be found in here. PLEASE READ HERE FIRST
                Car safety checks
                Fluid Capacities
                  It's a coupe-specific guide pin and it can be ordered as a kit from Honda to replace the missing one on your car.
                  Like Leung said, your original issue is the regulator. You'll need one from a coupe at the junkyard or you can buy one on eBay or at a parts store.
                    I thought it was the regulator, but every time I look it up it comes up with the power window version so I was second guessing myself. Thank you all for your replies.
                      For anybody else that might be searching this topic.
                      http://www.cb7tuner.com/vbb/showthre...window+pin+kit
                      http://www.dormanproducts.com/p-2267...520Pin%2520Kit
