Hello all. Thanks for coming. I'm having an issue with my cb7. It died on me coming home from work. Just shut off. It has fuel pressure and compression but no spark. I did the test with the light and the only igniter is working so I purchased a new coil and still nothing. I checked the ground by the thermostat housing and it's good. I checked if there's power to the dizzy and none. The fuses are good and I checked that relay under the steering wheel and it's good. What will cause no power to the dizzy. I also hooked my test light to the pos battery to check ground and there's no ground in the plug for the coil or dizzy. I'm stumped. Please help. Thank you again.
no spark issue
Well. After all the bull I found that the actual wire harness that goes to the dizzy was bad. Had to rewire it my self and replaced the dizzy because I was frustrated and threw it across the yard. I got good distance on it. Lol. Anyways. Any info on a coil over plug conversion? I thought I saw info about that here.
Originally posted by ZoneOneCB7 View PostWell. After all the bull I found that the actual wire harness that goes to the dizzy was bad. Had to rewire it my self and replaced the dizzy because I was frustrated and threw it across the yard. I got good distance on it. Lol. Anyways. Any info on a coil over plug conversion? I thought I saw info about that here.
Theres a few things about it. pretty sure you need a new cap with the correct coil plug and obviously an external coil. theres something here, just search it. dont use the forums search tool, it sucks. type in "external coil site:cb7tuner.com" and it will give you results from cb7tuner ranked by Relevance. works way better.sold! But here's my build thread for those interested.
