Go Back   CB7Tuner Forums > Beginner forum -- New members post here! > Beginner Audio/Electronics
Old 05-04-2018, 08:19 AM   #1
NolsAccord_CC1
NolsAccord_CC1 is cool... so far.
Unknown connectors under dash
I noticed some unused connectors under the driver side dashboard. What are these for? I have some issues with my car so I would like to know.
Here are the photo's:
NolsAccord_CC1 is offline   Reply With Quote
Old 05-04-2018, 08:37 AM   #2
Rilas
The black 8 pin plug is your fan timer switch, without it your cooling fans won't kick on. You have to drop down the cruise control unit to plug it back in. Kind of a pain in the butt.
Old 05-04-2018, 12:03 PM   #3
NolsAccord_CC1
Thx Rilas!
But last time I checked my fan did come on.
I'll look into it though.
I don't have cruise control so I guess it will be easy.
Anyone else knows what the other 2 are for?
Old 09-14-2018, 07:04 PM   #4
92Inspire
92Inspire is cool... so far.
Specs?
Coupe, Sedan, Wagon? Auto, Manual? Year? SRS System (airbags)? Ill see what I can find but I need all that info. I have it narrowed down to a couple connectors. Give me the exact number of pins on each connector (number of wires as well). A better description or picture of the connector location with a known connector reference.
Hey yo uhhhhhh fry man!!!!
92Inspire is offline   Reply With Quote
Old 12-11-2018, 10:23 AM   #5
NolsAccord_CC1
1992 manual coupe with SRS
View from wire side with tab down:
Little Brown 1P connector: light green (pastel)/Blue
Big Brown 6P connector: 5 wires:
Top row: GRN/BLK + GRN/WHT + BLK
Bottom row: no wire + WHT/BLK + WHT/RED
Small Black 8P connector: 7 wires
Top row: BLU + BLK/YEL + WHT + WHT/GRN
Bottom row: BLK + no wire + YEL/BLK + YEL/WHT
Newly discovered Grey 2P connector: 1 RED/YEL wire
Old 12-11-2018, 10:26 AM   #6
NolsAccord_CC1
They are all located under the steering column where the dashboard ends (towards the pedals)
Old 12-11-2018, 01:34 PM   #7
NolsAccord_CC1
Thanks Rilas! The black connector is indeed the cooling fan control, but i can't find the timer unit on my car. Is it near the fusebox? Is this timer unit for AC? My car doesn't have A/C.
When i bought the car the gauge cluster was broken and the temp gauge was constant in red. The PCB was Burnt and the red wire on the thermostat was loose and made contact with the transmission. That's probably why it burnt. Maybe the timer unit got damaged too and someone took it out.
Old 01-09-2019, 11:41 PM   #8
lindiz
lindiz is cool... so far.
The cooling fan control box is missing on CBs that didn't come with AC from factory, they just have the empty plug. Radiator fan works without this box, however to get the AC to kick on your fans you need this box.
lindiz is offline   Reply With Quote
Old 01-22-2019, 02:38 PM   #9
NolsAccord_CC1
Thanks lindiz!!
What about the other 2?
