Bad News...New Engine Swap
    Today, I got some bad news... Got my car looked at today after I notice some smoke coming out of my tail pipe that smelled like burnt oil. I need a head gasket, being that this my only car at the time I decided to put a new engine it that engine that I want. But I need a little help. I have a 1991 Honda Accord EX and I am looking to put a Prelude engine in but I don't know what year would fit in my car as well as will I have to change trans as well? These are questions that are really plaguing my mind right now. I don't want to get rid of her, I want to fix her, can someone help me PLEASE!
    There are metric tons of information for engine swaps in the "Swaps" section of the forums. I promise that all your answers are there.
    Any year can "fit" as long as you end up with it being OBDI compatible.
    Your F trans can bolt up, but it really neuters the engine imo. The short gears is what makes it fun.
    If you want to fix the car, replace the headgasket. If you are ready to do a swap, then you can for sure replace a headgasket. Also, you need a second opinion on the diagnosis. A burnt oil smell doesn't necessarily mean a bad HG...
    YouTube Clicky!!
      All the info you need is in the swaps section of this forum. The 92-95 H22A engine is the best choice in terms of performance and ease of installation. That swap is very well documented here. Please read through the H22A swap threads. Once you've done that, we'll be happy to assist with any questions you may have.
      And yes, the burnt oil smell doesn't necessarily mean a bad head gasket. It could be as simple as spark plug tube seals, or as severe as piston rings. Head gasket or tube seals are actually fairly simple to fix... far easier than an engine swap. Piston rings would be nearly as much work, though (so swapping in that case might not be a bad choice.) Still, I swapped when my transmission started grinding gears, so I know how you feel. Sometimes an annoying problem is just the thing you need to inspire a major upgrade!
        New the Lingo &amp; Site
        I did look at the swap portion of cb7 but nothing makes sense to be on there, and unfortunately I can't post anything on there because I am new to this it wouldn't allow me to post to that side. I just never had this problem with any honda I've had.
          If nothing makes sense to you there then you probably arent able to complete an engine swap. If youre taking it to someone to get swapped then theyll know how to do it as its actually extremely simple for an engine swap.
          Looking for a new CB. Sell me yours!
            Cb
            I will NEVER SELL my CB.
              nobody said anything about selling your car.
                Good luck.
                  Deever you're right, I had to replace my clutch so I used it as a reason to swap my f20b in. I love it so far... That vtec crossover and the 8200 red line is great. I noticed exactly what you meant about the torque difference between the h22. Gotta get the revs pretty high if u wanna move. But I love it so far
                    Thanx deevergote
                      I don't know your mechanical skill but based on your questions I don't think you will be able to swap the motor successfully.
                      Also as others have said "smoke from the tailpipe" is not a good indication of a blown head gasket. Do you have coolant under the oil cap? Bubbles in the radiator overflow tank while the engine is running? Low compression?
                      What's your goal here? More power? Why do you want a H22?
                      1992 EX, 306,000 miles - Track toy - M2S4, H23A1, ST rear swaybar, Wagon brakes, GC coil sleeves, KYB AGX dampers, Stoptech pads, Toyo Proxes R1R, 2.25" exhaust
                      Stock F22A6
                      VIR, 5/22/2016: https://youtu.be/eR5-ylSPsxk
                      H23A1 powered
                      NCCAR, 9/4/2016: https://www.youtube.com/watch?v=TI5WpxGrEpE
                      CMP, 10/16/2016: https://youtu.be/DOqoe5f-GLY
