Bad smell and smoke
    Bad smell and smoke
    I have a babied F22a6 with 245k miles. I get a weird smell, and smoke out of the exhaust when I rev north of 5k, but no smoke or smell under that, and no smoke on start up as far as I can tell. When at idle if I smell right next to the muffler it does not smell like burning oil. When replacing the plugs a while ago there was oil in the plug chambers on cylinders 1 and 2, and oil on the plugs. Do you think it's my piston rings, or some seals in the head? Which seals? I use Rotella T 5w-40 Full Synthetic to try and combat the burn-off, but it still happens. I'm not positive but I don't remember the smell when I used conventional oil, so it could be that the seals don't like the switch. I'm pretty sure it's some seals but let me know if you think I'm correct, and which seals to replace.
    When you hit that high of rpms you're most likely running rich and that could be part of the problem, but you could have the beginnings of valve stem seals leaking and/or you could also have the early stages of rings leaking. I would recommend a compression check (dry wet) and a leak down test. This will tell you more than our opinions would.
    The oil on the spark plugs is the result of the upper and lower spark plug seals leaking. I replaced just the uppers...and it worked for awhile...now my lowers leak. When I put my a6 cam in I will redo all the seals.
    ____
