Importance of fresh fuel before tuning???
    Hey all, Have a question regarding filling up with fresh fuel before a tune.
    Does it really matter how long I had my tank of 93 before a tune?
    I told my buddy its a good idea to fill er up beforehand, as the old fuel had been sitting in there about two months while we did the wire tuck, swap, and troubleshooting phases.
    Its been a long process, but we are actually nearing the end... hopefully!!
    I would like to hear what the community has to say on this matter
    I don't think two month old fuel is going to make a tremendous difference. My SE project may have sat for a year or more before I got it. It started and ran (not well) on what was in the tank; in that case, fresh fuel did make a difference.
      thanks for the reply... This is my assumption and hope it helps the tuner out. And for the sake of a good running and healthy motor!
      I've seen various YouTubers go to the extent of filling 10 - 15 gallons of their local 93 or E85 up in gas cans and taking it to a tuning session which is what had me thinking it would be a good idea to at least top off as much as I could prior to my session...
        2 months will not make a difference.
          Unleaded fuel has a shelf life of about 3 months. After that, it absorbs water. Just put some fuel stabilizer in there & it should stay usable for years.
            Two-month-old fuel is fine. If you’re getting tuned (and the engine is very heavily modified), then you’ll probably want to drain it. If you can drive the car, burn some of that old fuel off. Otherwise, fill it up with fresh 93, and it won’t likely be diluted enough to matter. Use a quality tier 1 fuel (like Sunoco), and try to get it from the newest pumps you can find. New pumps have better filtration, and if they’re attached to new tanks, less sediment/water risk.
            Also, be sure to check your spark plugs before tuning. Make sure they’re not fouled. Be prepared to slap some new ones in (after checking and setting the gap, of course!)
            I once fouled plugs after idling for an hour. Granted, I did it on 5 year old fuel.
