ROH Knuckle question
    OK,
    Well I've been a member for 2 years and for the first time I have a question that I couldn't find a straightforward answer to by searching. So now my first post.
    I have a 92 EX Coupe and I'm getting ready to do the ROH swap, as well as "beef up" to the 11" rotors. I planned on doing a knuckle swap using the knuckle from a 98-99 CL. In my searching I found that the 98 knuckle is different from the 98-99 knuckle and that the 98-99 knuckle wont work. HOWEVER, I then came across someone that has 99 knuckles on his 91 Accord.
    So my question is, what knuckles do I need to do a straight-up knuckle for knuckle swap?
    I already picked up a set of the VTEC calipers from a 94 Prelude as well as a set of rotors for the same.
    My second question - is there a list of cars that come with the 23T bracket out there somewhere?
    Thanks in advance for the help.
    Well, the CL is based off the CD accord really. The 98-99 2.3 CL I believe uses the same exact front knuckles as the CD accord 4 cyl (prob. should compare part numbers) and CD knuckles I believe are interchangeable w/ the CB. Only diff. is the CL/CD knuckles do not have the cover for the upper b/j nut. Plus also, aren't there a bunch of people that have installed 98-99 CL assy's on their CB's straight from the junkyard?
    As far as 23T's, Vigors have those as well.
      Thanks for the reply Granite. As far as this -
      That's exactly what I plan on doing since the JY is only going to charge me 50 a side if I take them out myself and I've seen a bunch of posts across the different boards that say "...I picked up a set of CL knuckles..." or ..."I have the CL Knuckles so now I have everything I need to do the swap..." but I've never seen anyone flat out say "Hey I just grabbed a set of knuckles and swapped them out - everything works great."
      Everything I've found hints at being able to swap out the knuckles but what year to grab I haven't been able to find out for sure.
        http://www.cb7tuner.com/vbb/showpost...2&postcount=15
        This post is one of the best on the subject, according to this, phatdoughnut is using CL front knuckles. Also, it states that the CB - CD - CL knuckles are the same, minus the cover on the CD and CL.
        There is also no difference in 98 or 99 2.3CL knuckles, both are 51210-sv4-j52 and 51215-sv4-j52 (right and left). All 2.3CL knuckles are set up for abs too.
