my 1/2 inch impact gun is on its way out!
    Hey my 1/2 inch cordless ryobi impact gun is going bad. The battery is fully charged but its the motor I believe that has me thinking its on its way out. So what should my replacement be?
    I've always been a fan of dewalt myself. My friend has a dewalt impact gun, and it has worked wonders over the years. Not too expensive either.
      I have used the dewalt cordless and it is a fine impact gun. The Milwaukee cordless tools are excellent tools as well that i have used with great success. The Hitachi brands of cordless tools are the unsung heros of cordless tool and my personal favorites, and when i finally kill my old ryobi's that will most likely be what i replace my tools with.
      CB7TUNER.com
        Which model do you have. Because my ryobi tends to do its job then literally stop then I got to put the battery out then put it back in again. Im not sure if its a battery or a gun problem.
          Ingersoll Rand
          YouTube Clicky!!
            Originally posted by sonikaccord View Post
            Ingersoll Rand
            Another recommendation for ingersoll rand.
            The IR W7150 is the strongest cordless impact gun I've ever owned. My friend borrowed it to remove the crank pulley bolt on his M3 after his cordless snap on impact gun failed to do so. I've also used it many times to remove the crank pulley bolt on the 2jz engine.
              whats the model number aswell as the torque specs on each one. My old ryobi which is on its way out has 280 tq.
                buy another ryobi unless your ready for big leagues. otherwise its a waste of money.
                i have one of these:
                https://www.amazon.com/Ingersoll-W71.../dp/B007LHJI4E
                780ftlbs reverse/1100ftlbs driving
                best cordless impact, period.
                Originally posted by wed3k
                  IR W7150 is the one to get
                  http://i220.photobucket.com/albums/d...82408002-1.jpg
                    droool.... so want to buy this. But I think it would get used twice a year
                      You can use it for anything. Wheel lugs, oil drain bolt, valve cover bolts...find an excuse to use it lol.
                      YouTube Clicky!!
                        I use mine every time I work on a car.
                        Down side to this impact, if you are fighting a bolt that is stuck, one of two things is going to happen. The bolt will come loose, or it will snap.
                        Snapping bolts sucks.
                          Also, make sure you grab the BL2022 battery if you come across one for cheap. It should give you a little more umph.
                          YouTube Clicky!!
                            I have a Milwaukee m18 Fuel half inch and that thing is fantastic. It can take out crank pulley bolts at the junkyard. It has two torque settings and the 4ah batteries charge in 15 minutes or less. It's a little on the pricey side but I promise you won't regret the investment.
