Also won't go into reverse or drive. The shifter goes all the way down to D1 fine but when running it grinds and won't go back into park. It was towed with a rope for 15 miles in neutral. I don't know what happened.
91 EX AUTO won't go into park while running
Trans
Both actually, check for any excessive slack that is not letting you select the gears properly. Overtime the mechanical parts wear and have excessive play and the cable stretches causing erratic gear selection, i have had more than a couple cars that did this; most recently my moms truck would not go thru any gear and the shift lever was loose, in her case the cable attached to the transmission arm had disconnected.
