SUSP: ABS removal.
    ^nice find
      just to update this on what ive found about doing this:
      it IS possible to remove the abs, lines and all, with the intake manifold installed. its a little harder but i think its better than removing it and having to replace gaskets. start to finish it took 6 hours for me to do it alone.
      On the issue with the master cylinder having a different size rear fitting, i went to autozone and bought an adapter for m12-m10 and used that instead of cutting and reflaring the line. so far it seems to work well.
      COUPE K24
        sounds good got a parts wagon getting ready to go to the scrapper. im going to grab the brake components, master cyl & booster and some other under the hood things. so i can do this swap and have larger rotors up front. my abs never worked when i got the car. the box was missing in the back something about moisture rot from hole's in the wheel wells. i have no fuses in the abs box. car stops very good
          Damn. Taking all the old stuff out was a bleeeeeep and a half. That was probably the worst task I ever had to do on this car. I pray the installation of all the new stuff slides into place smoothly like bleeeep in wet bleeeeeeep. Nevertheless, my ABS system is fully removed. It was a ton of weight too.
          The Lord watches over me!
          - D. Chappelle
            Originally posted by '93CB7Ex View Post
            reup.
            has anybody done this using an adapter for m10 to m12 for the lines? instead of cutting and reflaring?
            http://shop.advanceautoparts.com/buy...t-788-522.html
            Am using one so far so good!
              Is the abs control module in the same area in the wagon as a coupe or sedan. I'm doing the this weekend on the red wagon since the tranny is out.
              Red Wagon DD - 1993 EX
              http://www.cb7tuner.com/vbb/showthread.php?t=172734
              Gray Wagon Project - 1992 LX
              http://www.cb7tuner.com/vbb/showthread.php?t=166337
                Which brake line adapter do I really need?? I got the one mentioned above and won't work at all....part number from autozone??
                  What is the part number for the problem valve out of the integra? Does it have to ba a non abs car?
                    i've been thinking of doing this to my CB but looks like too much work. besides our cars, IMO, have the "simple" ABS (if that makes sense) which i can deal with lol
                    FRIENDS
                    DONT LET
                    FRIENDS
                    ROLL ON
                    ROTA'S
                      I'll be attempting this tonight as my engine is outta the wagon. Wish me luck
                      8 Accords so far:
                        A little late, but good luck.
                        - D. Chappelle
                          Currently in the process of doing this, What did you guys do with the wire harnesses?
                            Cut it out.
                            Actually, I think mine is still in the vehicle.
                            - D. Chappelle
                              Anything with orange plugs is ABS as far as I could figure out. I took out most of the abs wiring except for a few pieces I had trouble tracing back so they're just cut and I'll get to them later.
                                So pull the main wire harness unloom it and pull them out.
                                Thanks guys!
