Sedan vs coupe interchangeability
    Does anyone know what interior pieces i can switch from a coupe to a sedan?
    My heater console is broken and so are a few other bits and pieces..
    Does the whole dash fit between the two?
    Dash is 100&#37; the same. Center console (ebrake and such) should be as well. Everything else is different.
      Dash is 100% the same. Center console (ebrake and such) should be as well. Everything else is different.
      So the front part minus the door panels is the same? Awesome, thanks for the info
        Front doors are differents ?
          I would have guessed they are, yes. Like any other sedan Accord probably also has shorter doors than those off a coupe? Not sure tho
            Yes. Coupe doors are longer. Nothing swaps over.
              OK Thanks , I hope I will haven't any accident with my coupe
                Cannot positively say but possibly the following are the same:
                Front wind screen
                Rear wind screen
                Left and Right power mirrors and housings
                Electric antennae
                Front seats
                Front seatbelts
                Front external Door handle
                Front door lock striker mechanisms
                Front door solenoid
                Front door window motor
                Sunroof glass
                Possibly sunroof assembly itself.
                As I said haven't tried it but only from observation they possibly could be the same.
                Not highly confident with the front and rear screens as the rake could be different but worth a visual comparison up close.
                Rides:
                Accord
                CR-X
                88-JDM-Si- Black
                CR-X Del Sol
                92-JDM-SiR "Transtop" - Black
                Prelude
                  The top 3 are incorrect.
                    Front wind screen
                    Rear wind screen
                    Electric antennae
                    Front seats
                    Front seatbelts
                    Front door solenoid
                    Sunroof glass
                    pretty much none of those are interchangeable. except for the antenna, outer door handles, window motor, and sunroof (i think)
                      Electric antennae
                      Front seatbelts
                      Front door solenoid
                      I'd think atleast those are interchangeable.. Really gotta check the part numbers someday, it's got me puzzled right now.
                        Coupe doors are 10 inches longer than sedan front doors. I still occasionally think about stretching a CB7.
                        http://www.cb7tuner.com/vbb/showthread.php?t=195156
                          Thanks for the info. I've figured as much, just didn't realise they were that much longer..
                            You can swap trunks and Taillights. But they're not the same.
                            1993 Accord EX
                            2011 Subaru STi
                              I'm guessing the rubber gasket that goes around the trunk is the same too then? Mine is leaking
