Hello guys! I got a major problem, it's very irritating to see dried water spots on my windows after I had wiped them clean with alcohol and still won't come off. Any suggestions????? Thank You Very Much!!!!
Water spot stains on windows
As stated, if they were water spots, they should come off with cleaning. One alternative: http://www.cb7tuner.com/vbb/showthread.php?t=17152890 LX 4dr 5 spd 396,014 (sold 1/1/2022) - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=201450
sounds like Hard Water (mineral) etchings.
fleetw00d's recommendation on polishing would most likely take care of it. Before you go gung-ho with powered polishing you might want to test it out using a cloth, or a couple of the other options mentioned in this DIY:
http://cityscoop.us/honoluluhi-autod...ts-from-glass/
Originally posted by white92frankn View PostHello guys! I got a major problem, it's very irritating to see dried water spots on my windows after I had wiped them clean with alcohol and still won't come off. Any suggestions????? Thank You Very Much!!!!
I would start with vinegar first and see how it goes. If that doesn't work try adding some baking soda to form a paste.
If these remedies still don't do the trick it's time to look polishing as fleetwood and Mike have mentioned. You may want to consider Cerium Oxide Glass Polishing Compound. You can find this on Amazon and usually requires an electric polisher. I'd suggest watching a few YT videos first to see how it's done.
Hope this helps...Last edited by hiptech; 05-02-2017, 01:13 PM.
