Okay guys I've been putting this off for a long time but here it is. What's in the car now are stock springs that are heated down and compressed. I know this is unsafe. I seen some cheap coilover set off eBay and a few shops sitting on their racks. I feel like getting them but unsure of ride quality at that point. Any info guys will be appreciated!!! Thank You!!!
Aftermarket coilover
I used to have ebay coilovers when i first joined this community(08) and at the beginning it felt like it was a great idea but a couple months later i could not wait to take them craps off. Im gonna quote andre 3000 and say "Please dont do it, reconsider, read some lite-ra-ture on the subject". Truthfully man, ebay stuff(i mean that no name, $30 coilover and $8.99 intake) are aimed at those who want to be slammed without regard to comfort, safety or damage to their vehicle; at the end that cheap coilover ends up in the trash, you end up with a remorse and your car ends up with damage to other suspension parts like bushings, ball joits etc.
Cheap coilovers are about as safe as what you have now.
Cheapest quality (safe) suspension you're going to find will either be Tein Street Basis coilovers or Koni Sport (yellow) shocks with a reputable set of springs (h&r is my preference.) You'll also need an alignment, and potentially a camber kit depending on how low you want to go (less than 2" is usually safe with just a toe alignment)
If being lowered isn't important, and you just want a slight upgrade over stock, kyb quick struts are a good option.
That is true. I'm glad you mentioned that. I made that last reply on my phone, and I forgot to include that caveat! Tein is a BIG target for counterfeiters. So much that they even have (or at least recently had) a portion of their website dedicated to showing customers how to identify genuine Tein products and packaging!
I've had Koni Yellows and H&R Race springs on my own car. From personal experience, I can say that's a very good setup. For less of a drop, and a more comfortable ride, H&R Sport springs paired with the same Koni shocks would be quite good as well (I eventually swapped to that, but my car was smashed before I ever got a chance to drive on it.)
If budget is a concern you can consider the Koni Str.t Oranges. There is no doubt that the yellows are better designed and built shocks but the Oranges are a lot less and will work with a certain amount of lowering and will sufficiently dampen a pretty broad range of springs. We've got about 3,300 endurance racing miles on a set that are still going strong
Don't skimp on the springs. Many aftermarket springs have rates close to stock. That's not the worst thing, but if you are lowering you do want a bit stiffer or you could be bottoming out.
I know that Neuspeed Race are about 2x as stiff as stock and I wouldn't want them on my DD in the Bay Area. There is a post somewhere on this site that I found when I was shopping that had a list of springs, lowering heights, and spring rates. If someone knows where that one is, it should be sticky.==========================
1993 Accord Lemons Race Car, "SpaceEx Starship"
M2A4 Trans, Cusco 1-way Limited Slip Differential, Stage 2 Clutch and 11lb flywheel. A4 Header, 2" exhaust all the way back, catalyst delete, delta 262 grind, glasspack muffler, PT6 ECU.
Originally posted by ukemike View PostIf budget is a concern you can consider the Koni Str.t Oranges. There is no doubt that the yellows are better designed and built shocks but the Oranges are a lot less and will work with a certain amount of lowering and will sufficiently dampen a pretty broad range of springs. We've got about 3,300 endurance racing miles on a set that are still going strong
Here is the link to spring rates and such!
http://www.cb7tuner.com/vbb/showthre...ight=tein+tech
Koni's str.t shocks are definitely inferior to the yellows. They aren't even made in the same factory. I wouldn't use those with anything more than, say, neuspeed or h&r sport springs. They're not bad, but closer to stock replacement than anything else.
Tokico's only offering good for any significant drop would be the Illumina, which are priced similarly to the Koni Yellows, while being inferior. I still need to get concrete info on bilstein. They may have a non-adjustable shock for the cb that can handle a decent set of performance springs. Bilstein would probably be the highest quality shock manufacturer that caters to the cb chassis.
Originally posted by Crankshaft View PostHere is the link to spring rates and such!
