Turn signal 📶 lights for body kit
    I have searched everywhere for turn signal 📶 lights for my octane bumper kit for my 1991 Honda Accord. Does anyone know where I can find them. The company I brought the kit from told me that they don't sell the accessories such as lights. NEED HELP..
    You can use bullet light for trailers and semi trucks.
      Can you post a pic of the body kit? I looked online and the pics for the Octane kit don't show any additional lights on them. You can add lights to any bumper or fender but that's up to you.
        after market body kits usually dont have a place for the OEM turn signals and generally dont have a bolt in style for aftermarket body kits... Any turn signals you would want on the bumper would have to be fabricated...
          @Tishock: The picture that you have posted is my bumper. Yes the picture doesn't show lights but on 91 honda the turn signals are in the bumper. Kinda sucks, so right now i have no turn signals at all which is kind of unsafe. do you have any suggestions of what i should do?
            The corners have a turn signal as well. Like I suggested, look at trailer lights, truck lights or led strips to replace the bumper turn signals. You have to get creative.
              You should have turn signals in your corner lights.
              YouTube Clicky!!
                you could mount your original turn signals into the side openings on the new bumper. or find lights from a different car in the junkyard. or you could get slim LED strips from ebay.
                  cp[Mike] :How would i go about doing that? is there a thread or instrructions on how to?
                    nope, you'd be pretty much on your own. If you end up getting other lights, sometimes aftermarket ones come with mounting brackets? Otherwise you will need to fabricate your own way of mounting them up there, maybe you can use L-brackets and stuff from the hardware store? You can use pretty much any light that is 12 volts. Auto parts stores have a lot of random sizes for the sides of trailers and stuff. Then you just tap the 2 new wires into the existing 2 wires for the original blinker. If it doesnt light up, swap the wires around.
                    If you search google for "Amber LED turn signal universal" you end up getting a lot of options like the LED bars that you see on the Porsche below.
                      Thank you
                      thank you
                        91 honda accord corner lights are not turn signal ��
                          That's not true at all.
                          The corner lights have two bulbs in them. One is turned on with the lights and the other is a turn signal. The light in the bumper also acts as a turn signal.
                          Why would you think that the corner lights are not turn signals???
                            Because I don't have two bulbs in my corner lights and when I turn ny turn signal📶 lights on the don't blink
                              You should probably fix that. The corner lights ARE turn signals. If you have properly installed all of the bulbs.
