Turbo...help!
    Turbo...help!
    Whats up people,
    So i am rebuilding my Garret T40e 60Trim Turbo(part number on turbo 466159-5004)
    And i need to change the cold compressor wheel, anyone have any idea if im on the right track?
    This is what i have found so far.
    (My turbo)https://drive.google.com/open?id=0Bw...E1HM01LMHJuRjg / https://drive.google.com/open?id=0Bw...lRWbkg0ekJocWM
    (Possible replacements?)https://l.facebook.com/l.php?u=http%...DUPFnf1fVTBJxg
    Jesus drove a Honda, he just didnt talk about it like us. Proof - John 12:49 "For i did not speak of my own accord."
    den das al u ned u no dat u get wurs gas milge tho rite?
    60 trim, but t28. I don't know enough about turbo to know for sure, but that may not work. If you don't know enough about what you have, get something that it will work with exactly what you've got. Someone with actual turbo experience will certainly be able to help more, but just in case nobody has a better answer for you, stick to things that say exactly what you have... or contact Garrett directly.
      I sent an e-mail to Garrett about a week or two ago. Sadly no response, googling this turbo doesn't yield any answers for the correct compressor fan. I'm not sure what to do.
        So this is your turbo. Seems to be a type of turbo made Garrett, the T-type. But your turbo is a off brand they did with Honeywell. Still good, just seems to be really hard to find parts for or find on the internet period. I'm guessing that co-op Garrett/Honeywell didn't last long and thus this random brand. But no worries, same parts. You could get them from Garrett, APT, etc.
        http://www.atpturbo.com/mm5/merchant...de=GRT-TBO-034
        You're not the only one looking for parts for this, i seen posts on honda-tech, etc.
          I don't have anything to add here except that Honeywell is the parent company of Garrett and has been for a good long while. I'm sure there is a phone number you can call and find parts, typically Garrett turbos use a family of frames or center housing rotating assemblies (CHRA's) and the housings are then produced to fit different applications. Within the family of CHRA's you'll have different compressor and turbine wheels available that will be tailored to suit specific needs but these are often of the same profile at least as other compressor or turbine wheels and thus, are interchangeable.
          TL;DR, what you need is out there, you can spend hours googling about certain turbos and never find the information you need, but if you dig hard enough you'll find a phone number that will at least allow you to get forwarded to the right department where some old dude sits with dusty books in front of him and he will find you what you need and maybe even sell it to you on the spot.
          Good Luck!
