Old 12-10-2017, 03:26 AM   #1
CB7xBB4
CB7xBB4 is cool... so far.
intermittent no spark
so i've got no spark at the coil but not always when the car is cold it'll start and idle just fine, let it warm up and give it a little gas and it just flat out dies, once it dies ones it wont start again for like 15 min then it'll start and die out again in a few min or if i just give it gas
so tomorrow im taking out the main relay to look at it and make sure it's in good shape if this is not my issue could my coil cause this? why would it work partially when it wont's to. also if its my main relay that's pump and inspectors why do i still have fuel pressure but no spark.
im at a loss but im going to keep reading and keep looking, any advice would be greatly appreciated.
CB7xBB4 is offline   Reply With Quote
Old 12-10-2017, 03:39 AM   #2
CB7xBB4
sorry
i just found this and answered my own question (i think)
No spark
-check at coil, if good at coil replace cap and rotor.
-test light on positive and with cap off for internal coil, place on negative end of coil. Have someone turn the engine over, the test light should blink rapidly. if no blink or intermittent...check ignitor, positive end of coil for battery source and signal from ecu.
-if no power at coil + which is the blk/yellow wire, check ignition switch for power and main relay
http://www.cb7tuner.com/vbb/showpost...05&postcount=1
Old 12-10-2017, 10:34 AM   #3
sonikaccord
Those are the steps! If you can hear the fuel pump prime, the main relay is OK.
I would also add check the coil resistance if you have a meter. I can get those values if you need them
Old 12-10-2017, 03:23 PM   #4
CB7xBB4
it seems the main relay is in good shape, to be sure ill post pics asap and you guys can let me know for sure if that's okay, okay now to check the coil resistance how would i do this all I've been able to conclude is that I've got no spark at the coil, battery and alternator are brand new both tested bad at o'reilly's so i replaced them hoping this might do it, no luck. but if it is my coil why does it start and idle fine and why does it die when you give it gas? another thing i noticed is that i say it idles fine what i mean is it doesn't die but im not sure how okay it is for it to be idling at about 500rpm to me it sounds a little low but this is my first cb and i feel a little ignorant on the subject. thanks again.
Old 12-11-2017, 07:59 AM   #5
deevergote
Don't call me dude.
Idle should be between 700 and 800.
Check your grounds. Make sure they’re tight and clean, as well as both battery connections.
Old 12-11-2017, 11:49 PM   #6
Zombine
Zombine is cool... so far.
Maybe an intermittant open circuit in the TDC pickups? Have you tried a known good working dizzy? (Sorry if mentioned, only skim read the thread :P )
Zombine is offline   Reply With Quote
Old 12-17-2017, 03:40 AM   #7
CB7xBB4
it was my ICM
