I just put in new tie rods into the cb and made sure I went with quality Moog ones. The job all went smoothly, but when I went to go back out of the garage, my tie rods rubbed against the back lip of the wheel to the point where it stopped the car from rolling down the hill(I'll post a pic for reference of hill). It only rubs on full turn though. I'd take some pics but my phone was dying :/ Anybody know what could be causing this? I might just get 5mm wheel spacers and hope it doesn't rub?
moog tie rods scraping wheel
I had a similar problem on a tierod installation on a stock 94 Accord LX with Ex rims. I was certain I had used the right tierod ends but they were still grinding the car to a stop on what appeared to be the back of the rim...so I jacked the car up and put it in neutral so I could spin the rim by hand while under the car. Turns out the rods were wedging against the clamp-on lead wheel weights on the inner rim lips at certain angles. Popped them off and rebalanced the rims with stick on weights. Fixed
Im not saying this is your problem but...Last edited by 5sp5drCB; 04-07-2013, 10:09 PM.
Originally posted by illinois_erik View Postyup.
maybe L*R got mixed up
Originally posted by 5sp5drCB View PostI had a similar problem on a tierod installation on a stock 94 Accord LX with Ex rims. I was certain I had used the right tierod ends but they were still grinding the car to a stop on what appeared to be the back of the rim...so I jacked the car up and put it in neutral so I could spin the rim by hand while under the car. Turns out the rods were wedging against the clamp-on lead wheel weights on the inner rim lips at certain angles. Popped them off and rebalanced the rims with stick on weights. Fixed
Im not saying this is your problem but...Last edited by cuate01221; 04-07-2013, 11:39 PM.
