F22A1 cranking too long before starting when cold?
    My CB7 needs to crank for quite a while before it starts when its totally stone cold in the mornings. When its warm or hot, it starts instantly, as soon as I turn the key. Also, when its stone cold, and I turn the key on, and wait until I hear the fuel pump turn off, The engine will also start instantly. Is this normal behavior for F22A1 engines? Is there something wrong or is a part failing? The car has 181,000 Km and was babied for its whole life with regular oil changes and fluid changes. I bought it November 2016
    Betty and Betzi died for our sins
    There is a check valve in the fuel pump that, in conjunction with the fuel pressure regulator, is supposed to maintain pressure in the fuel line up to the fuel rail on the engine. If the check valve or pressure regulator leaks, the line pressure will drop, then when you try to start it cold by turning the key immediately to "start", it takes a short time to pressurize the line before it can start injecting fuel correctly. By waiting the two seconds for the pump to turn off, you've given it time to pressurize the line so that when you do turn the ignition to "start" it has fuel pressure. It starts OK warm because it hasn't had time for the pressure to bleed off. If you want to confirm this, install a fuel pressure gauge, start and run the engine briefly to pressurize the fuel line, then let it sit overnight and see if it maintains pressure.
    I wouldn't change a fuel pump just because of this; just be patient and wait the 2 seconds before turning the key. You could try installing a new pressure regulator (left end of fuel rail). You might try running some fuel system cleaner through the tank; it may ungunk/unstick the check valve and/or the regulator.
      Although fleetw00d is probably correct, I would also suggest cleaning up your battery terminals. Corrosion on the terminals can result in a hard start situation. It's an easy fix, and smart preventative maintenance. Also make sure your battery cells are topped up with water if it's not a sealed cell battery.
      Additionally, check the condition of your spark plugs, distributor cap, and rotor. Honestly, it probably wouldn't be a bad idea to change all that stuff if you haven't done so already.
        If not the check valve then most likely new filter needed
