what ecu should i use
    with a bisimoto headers, what kind of ECU should i use?
    A Stock or tuneable ECU
    YouTube Clicky!!
      A stock ECU will do just fine with a header. It's when you go well beyond the common intake/header/exhaust that you should start to think about a tunable ECU.
      Originally posted by Junior Smurff
        Bisimoto are a generic F22A header. Unless they were built for a custom built engine. All you need to run is the stock ECU.
        MR Thread
        GhostAccord 2.4L Blog
        by Chappy, on Flickr
          Exactly. You MIGHT be able to see some additional gains by getting a tunable ECU or other engine management system, and having it professionally tuned on a dyno... but that's an awful lot of work and money for minimal gains. The stock ECU will handle it just fine. Look into a tunable ECU/EMS when you do a camshaft upgrade, or increase compression.
          Also, since it bugs the shite outta me... you only have one header. Not "headers".
            alright, thanks!
              So now your looking into a Bisimoto header but want to swap in an H23a?
              ~Nick~
                He's trying to build a naturally aspirated turbo engine with single-lobe VTEC and carbureted fuel injectors.
                  Makes sense, don't go into boost there's you n/a, boost you got the turbo, install toda cams minus the vtec part so you maintain the single lobe but have vtec and install ITBs and you can accomplish this. Sorta
                  ~Nick~
                    Relevant.
                    sold! But here's my build thread for those interested.
                    http://www.cb7tuner.com/vbb/showthread.php?t=206864
                      lmao. sorry for the spelling but reading on some advice here i went with the stock ecu. maybe ill change it up when doing some more mods and tune.
                        Good.
                        The first rule of modifying your car is this: if you don't understand what you're doing, don't do it.
