Issues with my F22B DOHC
    Solenoid? Do you mean o2 sensor?
    His was in good condition before the swap.
      I had a beer to much Sensor it is
      Strange
      Vacuum problem?
      Your car is faster, I'm the better driver
      Greetz Erwin
      My last ride
      Shakes and Fidget - The Game
        Strange
        Vacuum problem?
        Yesterday I took off my intake and plugged the upper hole in the throttle body(car almost died)
        Then I put my finger over the lower hole and nothing happened.
        3 CB's gone....
        1 WK Overland....
        Still miss the CB though......maybe one day.
          im pretty sure you guys tried a f22a ecu already right?
            Yea, he said it does it with the stock f22a1 ecu and my chipped ecu.
              is EGR hooked up? how dirty were the ports? have you seafoamed?
              still sounds like an eletrical problem. i thought you guys got a new distributor........???.....
              F22a1-->F22A-->H22A-->auto-2-5spd-->K20 6spd-->F22C 6spd RWD-->4G63 6spd AWD-->K24 6spd????
              Sold to: blackice, Myothercar, Rennat, Ilikebigbutts, HA91, DA92CB7, accord91lx, Cb7GHOST, Gemini, whiteaccord92,Warudakumi, jhondayaaj
              Bought from: 93twodoorLX, Datmofo, g7kobayashi, accord_inspire, Accord SiR, Kurobei, UK-Accord, phreakish93, RENR, k-mart
                EGR is hooked
                Have not used Seafoam and yes we did get a new dizzy.
                3 CB's gone....
                1 WK Overland....
                  Originally posted by 91Accord-LX
                  EGR is hooked
                  if its a new dizzy, then that should be ruled out. i would think.
                    Alright, so we set the timing at 15 degrees. It was retarded, for some reason. I swear I put it past the center.
                    Anyways, it fixed the idle some, and some of the driving issues.
                    It back fires right before it shifts. Also, when you step on it, the rpm's fluctuate quite a bit, while wot and just cruising. There's no more jerking tho.
                    What wire goes to the tach? TDC?
                      blue wire for tacho.
                        did you say taco?
                          The car is running pretty strong except those intermittent rpm fluctuations. Usually only between 2.5k-3.5k and under certain throttle.
                          freaking weird.
                            using the MSD coil? and the igniter is brand new?
                            but the EGR valve is old? hmm try some seafoam guys.
                              Yea, using msd coil, igniter is good. The EGR came off the f22a, we cleaned it before installing it.
                              I'll ask Alex and see if he wants to seafoam.
                                Fucking shit man!
                                Alex texted me on his way to work and said it's acting up again. WTF!
                                NO seafoam yet, but still, wtf man.
