Alarm wiring diagram for my cb help :P
    Hi guys and girls,
    As usual i have a pretty avergage question :P, anyway does anyone have a wiring diagram to install an alarm my local store told me to google for one but am having a hard time finding one thats deacent. Im planning to get a warlock kg800 or kg1000 any help would be great.
    Thanks
    Anthony
    Google is your friend. This took me literally three seconds.
    I predict that it will take you about two to three hours to install your first alarm correctly. I'd personally forget the Warlock and go with the Astra 777. I've had mine for years now and haven't had any problems with it at all.
    12 VOLT CONSTANT WHITE (+) @ IGNITION SWITCH HARNESS
    STARTER BLACK/WHITE (+) @ IGNITION SWITCH HARNESS
    STARTER 2 N/A
    IGNITION 1 BLACK/YELLOW (+) @ IGNITION SWITCH HARNESS
    IGNITION 2 N/A
    IGNITION 3 N/A
    ACCESSORY/HEATER BLOWER 1 YELLOW (+) @ IGNITION SWITCH HARNESS
    ACCESSORY/HEATER BLOWER 2 N/A
    KEYSENSE N/A
    PARKING LIGHTS ( - ) N/A
    PARKING LIGHTS ( + ) RED/BLACK (+) @ FUSEBOX IN DRIVERS KICK PANEL
    POWER LOCK BLACK/WHITE (TYPE B) LOW IN DRIVERS KICK PANEL
    POWER UNLOCK BLACK/RED (TYPE B) LOW IN DRIVERS KICK PANEL
    DOOR TRIGGER BLACK/WHITE (-), @ BROWN PLUG LEFT of STEERING COLUMN
    DOMELIGHT SUPERVISION USE DOOR TRIGGER,
    TRUNK RELEASE N/A
    SLIDING POWER DOOR N/A
    HORN LIGHT GREEN/BLUE (-) @ STEERING COLUMN HARNESS
    TACH BLUE (AC) @ DISTRIBUTOR
    WAIT TO START LIGHT N/A
    BRAKE GREEN/WHITE (+) @ SWITCH ABOVE BRAKE PEDAL
    FACTORY ALARM DISARM N/A
    ANTI-THEFT N/A
      STARTER 2 N/A
      IGNITION 2 N/A
      IGNITION 3 N/A
      KEYSENSE N/A
      TRUNK RELEASE N/A
      ANTI-THEFT N/A
      Is that for the car or alarm unit?
      I think he wants the diagram for the car.
        I'd get an astra system but i need something cheap and cheerful and for me to find at a local store if you know one in a store in AUS thats cheap id buy it but this seems adequate.
          Those are the wire colors and locations for the car wiring he needs to use. The diagram for the car isn't going to be any more helpful than that, it looks like hundreds of lines. lol
            That's most definitely not cheap for such a basic alarm setup. For the same price, you could order the 777 from amazon or ebay and have it shipped. I'll never go back to a one way pager again.
              My friend has one of these so it will most likely be this http://www.jaycar.com.au/productView...m&form=KEYWORD any opinions here?
                Do people knot know about ebay in aus lol ?
                I found this one in 30 seconds and it is half the price and way nicer ,plus it has remote start> http://cgi.ebay.com/ebaymotors/Land-...fAudioQ5fVideo
                  I bought myself a python 310 for $150 even though ill probably stuff up with installing it as i cant afford to get it installed D:
