I need to replace my right front hub bearing. I decided since im at 200,000mi i might as well do both fronts at once and hopefully be good for another 200,000. I'm trying to find good instructions on how to do it but everything i find tells me when I get to the point of getting the hub off the car to take to a machine shop to have it pressed out. Being as I am a manager of a Machine shop that shouldn't be to hard, it just that i have no idea what to press out. Will i see the bearing in there easily? I just replaced my CV axle and i was trying to see the Bearing but i wasn't exactly sure if i was looking at the right thing. if anyone can give me descriptive detail on this it would be great. thanks in advance.
Hub Bearing Replacement
My understanding is (without having done it myself yet) that one way to do this is:
If you remove the 4 10mm bolts, then thread some really long 10mm bolts in their place, (long enough to stand back from the knuckle to allow you to hammer on the bolt heads), you can then usually hammer on the heads of the long bolts and that will shock and press/remove the hub and rotor assembly from the knuckle.
Then you can take that assembly hub and rotor assembly and press the rotor away from the hub or vice versa in a press.
Since you're putting in a new hub unit it doesn't really matter if you mess the old one up while removing it.
That's how I believe it can be done without removing the steering knuckle from the car.
The hub/rotor assembly is supposed to just slide off once unbolted but never does by all accounts, it usually gets seized on.
Originally posted by project93 View PostI just replaced my CV axle and i was trying to see the Bearing but i wasn't exactly sure if i was looking at the right thing. if anyone can give me descriptive detail on this it would be great. thanks in advance.
Well, remember when you put the end stub of the CV axle into the hub unit, then threaded the axle bolt on it? If you looked closely at where the axle went in, (and I'm sure you did), it has a splined pattern all around the inside of it to mate with the splines on the the axle end. That splined area is the inner sleeve of the hub unit, and it is assembled over the rotor on a normal cb7. If you had taken your finger and pressed on the hub splines, you would see that they rotate under hard finger pressure (or if your hub is shot, under much lighter finger pressure).
The hub and rotor are attached to the knuckle by 4 bolts I believe. Again, I haven't done the job but I've looked at the hub and read about doing the job.
hope that helps.
