hey guys, i was wondering if an ecu for an h23 will work with my f22b dohc. some people told me that the h23 ecu will not open the secondary butterflys. can i just remove them as some have said. trying to locate the p39 ecu is impossible. i have only found one and the person laughed when i offered him $300.00 for it. REALLY need to know. thank you in advance.
f22b dohc swap
1. I dont think there are secondaries on an f22b dohc (correct me if I am wrong but I dont remember seeing them on there)
2. H23 distributor will work just fine.
3. The p14 (h23 ecu) will work but you need to wire in a knock sensor.
4. You offered 300 for an ECU??? You might as well get a chipped p06 and go get it tuned by someone.
The New-ish Ride
My old Ride
Hear my Vtak!!!
MK3 Member #3
I piss off people for fun.
IA 08 Sunburn Victim #1
The F22B DOHC does have IAB butterflies, the intake manifold is the same as the US H23a1. The p14 and the P39 are both Capable of opening the Iabs at the preset rpm. I tried a P14 on my F22B and could not get it to stop throwing the ks code even after tapping threads into the back of the block and installing a new ks sensor there. Try emailing Nagano Japanese, I got my M/T P39 from them and it wasn't anywhere near $300. They probably won't have it in stock but they should be able to get one for you.
