Old 09-22-2017, 10:00 PM   #1
Rat
Rat is cool... so far.
Rounded Head Bolt
So I am removing the head from my 1992 accord. I busted the socket i was using and rounded the head beyond any hope of extraction. Now, i need to know the best way to at least cut the head of the bolt off so i can finish removing the old head. I should add that the head is already badly damaged so im not afraid of damaging it further. Should i drill through the side of the head into the bolt? Or does someone have a better idea? Thanks.
Rat is offline   Reply With Quote
Old 09-22-2017, 10:40 PM   #2
Jon
Jon is very helpful Jon is very helpful
Which bolt and where exactly is it located? Pictures do help as there are a lot of options depending on how much of the head is left, where it's located, etc..
Jon is offline   Reply With Quote
Old 09-22-2017, 10:44 PM   #3
Ghostwhite
Ghostwhite is cool... so far.
It would help to know which bolt specifically, maybe even a picture. I have used a few different methods on bolt extraction but my favorite if possible is probably a vice-grip as tight as you can possible get it.
If you can sometimes it helps to heat the bolt head with a handheld torch and melt some crayon wax into the threads.
If you have to cut the head off you will still have to get the rest out and its easier if there is something left to grab.
Edit: Too slow, Jon covered most.
Ghostwhite is offline   Reply With Quote
Old 09-22-2017, 11:32 PM   #4
Jon
Great minds think alike.
Old 09-23-2017, 01:50 PM   #5
fleetw00d
fleetw00d seems to have made some friends! fleetw00d seems to have made some friends!
They do make sockets that are designed to grip stripped bolt heads; check your local hardware or auto parts store.
90 LX 4dr 5 spd 364,000 - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=201450
93 LX wagon auto 245,000 MRT:http://www.cb7tuner.com/vbb/showthread.php?t=208490
92 EX coupe auto 167,000 - MRT:http://www.cb7tuner.com/vbb/showthread.php?t=205114
LOTS of CB7 parts for sale http://www.cb7tuner.com/vbb/showthread.php?t=192583
Working to relink my pictures. Please be patient. If there is one you particularly want to see, let me know.
Old 09-23-2017, 03:52 PM   #6
Grumpys93
I have one of these. It's called gator grip/ so far it's been 50/50 with it working.
~Nick~
Grumpys93 is online now   Reply With Quote
Old 09-23-2017, 09:28 PM   #7
illinois_erik
Pound one of these bitches on there, its coming out. Make sure next time you use the right size socket
https://www.harborfreight.com/9-pc-3...set-67894.html
that gator grip is some cheesy crap for bored housewives to order from the home shopping network, for their husbands who will a)never use them b)if they do, it breaks. plus itll be too large in diameter to fit (the other ones might even be a shade to large too.
if the head is garbage, sawzall it away and chisel out the last bits so you dont mar the blocks mating surface. there will be enough of a stud left to grip with vice grips or weld a nut on.
Old 09-23-2017, 09:55 PM   #8
Jon
Not all methods or tools work for every broken bolts or screw, so you kind of stand back and look at what you're dealing with.
Left handed drill bits works well for 50% of the screws/bolts. Just make sure you have a good centerline on the bolt before drilling. Cutting the top of the screw/bolt flat and using a punch to get a center is a good start.
If you have a good amount still sticking out, welding a nut onto the broken bolt can work. Same with those bolt extractors. The ones Erik posted that grab onto the outside of the bolt work way better than the ones you try to drill a hole into the bolt with and try to screw it out (aka easy-outs... never had luck with them at all).
Hope the OP has had some luck...
Old 10-17-2017, 06:54 PM   #9
Darkcloud
Darkcloud is cool... so far.
Happened to me a few months back, I used a smaller socket 13mm 6pt. I hammered it on til it fully seated. And slowly turn the stud. Had 3 stripped bolts and all came out easy
Darkcloud is offline   Reply With Quote
