Shift Points
    Shift Points
    Hello I have a 1990 HONDA ACCORD EX automatic it shifts around 3,000 normally depending on throttle position but that's just normal driving/taking off what does your car shift at? And is 3,000 about normal?
    I shift whenever I want (I drive a 5speed)
    Like you said, with an automatic the shift is depending on throttle position, so yes, for your throttle position 3000rpm is probably fine.
      That's around what mine shifts at under regular driving conditions. Should be normal. Do you have concerns about your transmission?
        I wouldn't say any concerns but when I go to floor it, It shifts down but it takes a few seconds to do so assuming it's just because it's a older transmission but not sure if it's normal or not it shifts fine otherwise.
          That sounds like your transmission is functioning properly.
            Sounds completely normal to me.
