WiccanVampier's Official Boost Thread...finally...(56k warning)
    OK!
    So after years and years of buying parts, it's finally starting to come together. The shortblock is assembled and I just got my head back from the machine shop yesterday...now I just have to find some time to get it assembled and in the car...
    Here's the plan.
    450+whp @1.0Bar
    F22a Non-VTEC, stock head, stock block (Read- No porting, stock sleeves)
    H23 5spd transmission, ESP.net mounts and traction bar w/ front torque mount
    Engine:
    -Wiseco 8.8:1 pistons, Teflon coated skirts, Ceramic coated tops
    -4340 chromoly H-beam connecting rods
    -ACL Race bearings, Calico Teflon coating
    -Kaizenspeed balance shaft eliminator kit
    -Si Std size SS valves
    -Bronze valve guides
    -Viton valve seals
    -5 angle valve job
    -Lightened and polished rocker arms
    -Bisimoto valve spring and Ti retainers
    -Bisimoto 1.2 turbo cam
    -Bisimoto cam gear
    -UR lightweight crank and alt. pullies
    -ARP head studs
    -OEM MLS headgasket
    -Modified OEM oil pan
    -H23 IM
    -Deleted IAB's
    -Skunk2 68mm throttle body
    -ID1000 injectors
    -Bosch 044 fuel pump in-tank
    - -8AN fuel lines
    -Adjustable fpr
    -Hondata S300
    Turbo:
    -Garrett T3/T67 67ind, 84exd, .63 A/R
    -Modified OBX Ramhorn turbo manifold
    -42mm wastegate
    -3" downpipe
    -VRS 3" mandrel bent exhaust
    -Magnaflow 3" cat and muffler
    -GReddy Type-S bov
    -Custom oil feed and return lines
    -Custom air-water intercooler
    -5gal trunk mounted resevoir
    -Bosch Ford SVT water pump
    -Dual pass aluminum heat exchanger
    -3" aluminum intercooler piping
    -Civic half radiator and FAL slim fan
    I will post pics next week of the engine assembly. Hopefully I will also find some time to paint my engine bay and tuck my headlight wiring harnesses.
    SOHC Non-VTEC F-series for life
    "It is the fools prerogative to utter truths that no one else will speak."
    -Morpheus (The Sandman)
    Nice
      Man, i sorta wish I boosted...
        None but red X's.
          had me mad hyped......but all i see are red x's...
            They were working 5 minutes ago....stupid geocities...gimme a little while to work this out. I promised I'll get the pix to work again
              use photobucket.com
                pics no workie!
                92 DA9 // 93 D21 4x4 // 92 CB7
                  Alrighty, sorry bout that guys, moved them to PhotoBucket, and they're working now, enjoy ^_^
                  -Kyle
                    nice start man! are you gona use the dsm manifold? what turbo did you buy?
                    -Jose
                      No it's a log manifold, you can see it next to the cam in the first pic. It will be a Turbonetics T3/T4 turbo.
                      -Kyle
                        Bump! Turbo will be here on Friday, pics will be up the moment it comes in!!!
                        -Kyle
                          very nice part compilation so far. next up, a CB chassis!
                            Yeah that's gonna be the hardest part. Anyone know of anybody selling a CLEAN Black 92-93 Accord EX 5spd Coupe??? I can't find any that are exactly what I want, and I will not settle.
                            -Kyle
                              Looks like u off to a good start wit the "project cb7 turbo." I been startin for like the last month, but damn, I ain't even order the first part yet (LOL). Well.... if u decide to go awol wit the project, I gotta good home 4 it j/k.
                              Check out what used to be mine
                              Click Here
