Old 03-04-2010, 11:21 AM   #21
19dabeast85
19dabeast85 is cool... so far.
Ok so I just stepped through their process. It seems for whatever reason they only have a straight m12 x 1.0 fitting and no 90 degree 12mm bends listed. You may need to call them up as I'm sure they have the fitting available. If not, the -3 an line bends at a minimum of a 2" radius. My MC end fitting is the straight fitting listed and it's bent about to the max, I was able to install it without removing the clutch MC though so not a HUGE deal if you have to go with the straight fitting. I'll try to find a pic of it and post up...
Oh and make sure the slave end is a swivel fitting so you can install and remove it easily.
My Member's Ride Thread
19dabeast85 is offline   Reply With Quote
Old 03-04-2010, 11:25 AM   #22
PR CB7
PR CB7 is cool... so far.
Send a message via MSN to PR CB7
43" is the right size for the cb
its what i currently run right now
45deg fittings on slave-43"line-45deg fitting -adapter to MC
also if you happen to get a flat end on the banjo bolt, you'll have to drill it just a bit, because the MC is inverted flare
Just do what PR CB7 said.
PR CB7 is offline   Reply With Quote
Old 03-04-2010, 07:52 PM   #23
drummersteve7
Boost Junkie Rehab!
drummersteve7 seems to have made some friends!
here is what I got.
I figured if I put red loctite on the fittings then I will not have to worry about the psi breakin the seal.
what do ya think?
MadLab Racing
Southern Maryland
drummersteve7 is offline   Reply With Quote
Old 03-04-2010, 09:08 PM   #24
PR CB7
the fitting on the MC has to be inverted flare,
and dont worry about leaking
thats why flare was invented
enjoy
can you say INSTANT CLUTCH BLEED
Old 03-04-2010, 11:22 PM   #25
drummersteve7
Boost Junkie Rehab!
difference between inverted flare and convex?
convex tapers down and inverted flare goes straight down?
am I correct?
I ordered 12x1.0 convex to -3an, this will not work?
cause that is what I ordered and received.
this:
http://www.pegasusautoracing.com/big...asp?RecID=5935
MadLab Racing
Southern Maryland
Old 03-05-2010, 12:02 PM   #26
19dabeast85
am I correct?
this:
Oh ok, so you did buy a line made by them. I got the line special made so I didn't have to use the adapters but your method should work too.
However, if you look down inside the clutch slave and MC holes you will see that they are both convex "pointing out" so your adapters need to be concave "inverted" to mesh and seal properly. There is no need to use locktite or any sealant on the fittings or threads, they won't loosen. Also remember not to over tighten them, these fittings only have to be a bit more than snug.
Old 03-05-2010, 12:04 PM   #27
drummersteve7
Boost Junkie Rehab!
yah cool, I know how they work, use em lots for turbo oil fittings.
ok so just get concave instead of convex and I should be good?
MadLab Racing
Southern Maryland
Old 03-05-2010, 12:11 PM   #28
19dabeast85
Yep, If my memory serves me correctly, both mc and slave are convex so you should be good with the concave ones. I wish I had taken pics of mine before I installed it.
Old 03-05-2010, 12:22 PM   #29
drummersteve7
Boost Junkie Rehab!
well I pulled my slave cylinder and inside the cylinder in convex, so I should have ordered concave. Is this the same as Inverterted?
MadLab Racing
Southern Maryland
Old 03-05-2010, 12:48 PM   #30
19dabeast85
Yes, concave= "cave in a mountain" = inverted. The same.
Old 03-05-2010, 07:04 PM   #31
drummersteve7
Boost Junkie Rehab!
Well parts are now ordered.
So I will have everything I need soon.
MadLab Racing
Southern Maryland
Old 03-11-2010, 03:59 PM   #32
PR CB7
"whaty kind of flare is it?"
what does it look like?
hmmmm i dont know
does it look like a cave in a mountain
huhhhh wtffff well actually it does
Old 03-12-2010, 06:21 AM   #33
19dabeast85
hmmmm i dont know
lol, ever since grade school science and learning about different magnifying lenses, that's how I've always remembered the difference between convex and concave.
Old 03-12-2010, 06:43 AM   #34
drummersteve7
Boost Junkie Rehab!
they sent me the 12mm ones, I ordered both.
hmmm so now i gotta find a concave 10mm!
and that is all!
MadLab Racing
Southern Maryland
