Old 08-27-2014, 11:11 AM   #1
Oso79
Newcomer
Oso79 is cool... so far.
Angry Overheating Problems
I got a 92 sedan F22A1 that still over heats after a week of fixing. Had head gasket replaced and heads resurfaced, new radiator, water pump, thermostat, radiator cap, hoses, plugs and wires, timing belt. Worked well for a week then started to overheat again until I blew the head gasket again. Is there anything else I might have missed? Stressed
Oso79 is offline   Reply With Quote
Old 08-27-2014, 11:25 AM   #2
Jarrett
Contributing Member
Are your fans coming on like they're supposed to?
Were you not watching your needle like a hawk the second time around?
__________________
Old 08-27-2014, 12:02 PM   #3
Oso79
Newcomer
Yeah the fans came on when they needed to. I was watching it like a hawk. The needle went up at a stop light then went down once I started going. This is what happened the first time. I can also smell like burning oil once I parked it and turn it off but not sure if it is or not,
Old 08-27-2014, 04:36 PM   #4
Kev1990
CB7tuner Member
Kev1990 is cool... so far.
Did you bleed the cooling system through the valve? If not I would try that.
Kev1990 is offline   Reply With Quote
Old 08-27-2014, 04:43 PM   #5
Oso79
Newcomer
Yup I bled the system already, I'm stuck haha literally.
Old 08-28-2014, 09:30 PM   #6
wildBill83
CB7tuner Member
wildBill83 seems to have made some friends!
Is your tstat installed backwards? Do you have any leaks? You might have a bad head gasket and that is the primary problem. Did you do the work? If you had a shop do it I would be taking it back.
Really sounds like a headgasket problem to me. Exhaust gasses getting in the coolant will overheat your motor in a hurry.
wildBill83 is offline   Reply With Quote
Old 08-30-2014, 08:03 PM   #7
CaSpAr4Rm916
Newcomer
CaSpAr4Rm916 is cool... so far.
Send a message via AIM to CaSpAr4Rm916
Wink Remember
Always! An i mean always, reset your ecu box. I'd help my younger cousin replace his electrical problems an check engine came on. Anything to do with wires, always reset the ecu.
CaSpAr4Rm916 is offline   Reply With Quote
