Idle Issues
    Idle Issues
    So, for a while I have been having an issue with my idle. It was not revving up and down like a vacuum leak but, more like the idle was sitting too high. For example, if I was coming to a stop for a red light, the idle would stay at 1,200 RPMs even as I finally stopped.
    I tried to clean everything I could think of such as, throttle body, FITV, IACV, and even tried to cap off the air boost valve. I did not clean the ERG yet though. It helped a little when I cleaned out the FITV and re-tightened the white piece inside back down, with about 1/4 turn back off. But, my idle still liked to sit at about 1,200 RPMs no matter what. I also tried to spray some carb cleaner around the IM but nothing happened to the idle. This helped rule out a vacuum leak.
    I found the article about resetting the base idle. Luckily, it actually helped bring the idle back to normal (around 800 RPMs while at a stop.). So, I do not know if anyone may have a similar issue but, follow the thread on Resetting the Base Idle by HondaFan81 if you may have a similar issue because it really helped me.
    "SETTING BASE IDLE PROPERLY" -> http://www.cb7tuner.com/vbb/showpost...33&postcount=1
    Last edited by G. Wiffington; 04-24-2016, 06:13 PM. Reason: Edit title for another Link
    Keep Pushing..
    That's why we put it in the thread at the top marked "PLEASE READ HERE FIRST"
    Can't hurt to have yet another thread pointing to it, though. Glad it helped you fix the problem!
      Haha yeah I guess I should had done a tad more research on here but hey, it's all good now! I love the info on here, you just really have to navigate to find what you are looking for. Thanks man, I appreciate it.
      && plus I just wanted to make a thread that actually says that information on here was beneficial. Sometimes I see threads where people discuss their related issues on a certain topic but never say if everything worked out in the end.
      Knowledge is power!
      Keep Pushing..
        A lot of people have the same issue you had. I've directed them to that thread, and they almost always say "I did that and it didn't work". I wonder how many actually read the thread and followed the steps! Idle issues are common on these engines, and there is a LOT of misinformation out there on how to fix them (some of it, sadly, is still lurking on these pages.)
        We do our best to put links to some of the most commonly used information at the top of each relevant section. If there's ever anything you come across that you feel belongs in one of those index threads, don't hesitate to message me or an active moderator!
          Yes sir, I agree. From what I have seen on this forum, there is a great amount of information that other CB7 Family members can use.
          I am honestly on here everyday looking across pages just because I like reading about other member's experiences.
          I wish there was a CB7 Family Chapter out here in Baltimore, Maryland!! I am trying to get my younger brother into cars so hopefully I can find a nice CB around my area to build with him. (Sorry to get off-topic haha.)
          Thanks for the feedback deevergote, I appreciate it.
          Keep Pushing..
            The founder of this site was actually from MD!
            There used to be quite a crowd in the mid-atlantic region.
              Haha really? That is awesome!!
              Yeah Maryland is the spot to be. (Lmao that was complete sarcasm.)
              I feel like I used to see a larger import scene in the early 2000's when I was younger but, now I really don't see that many anymore. A few turboed Civics every now and again but, I honestly have not seen a single CB7 that has been taken under our caring car-enthusiastic wings. I swear it's like spotting a unicorn when you see a nice CB riding down the road!! Although, there is a nice rusty 1991 CB up the street from me hahaha.
              Keep Pushing..
                You may still have a bit of a leak through the FITV; the internal o-ring on the yellow piston takes a compression set so that it no longer seals well. Link for replacing the o-ring: http://www.cb7tuner.com/vbb/showthread.php?t=206012 which may help with cold starts when that time comes again.
                  The import scene isn't what it used to be, that's for sure. When it first hit the mainstream (basically, as soon as The Fast and the Furious came out), it was something special and exclusive. Then it got flooded with idiots, and the cheap aftermarket parts started popping up everywhere. The real enthusiasts got buried somewhere between the people who paid WAY too much money to follow a trend, and the people that cut every imaginable corner in order to do as many modifications to their vehicle for the least amount of money. Eventually, the automakers caught on, and started giving us cars that had all the things that we were doing on our own... turbo, HID headlights, crazy powerful engines, performance aerodynamic bits, limited slip differentials... some manufacturers, like Hyundai, even designed their ECU in a way that it was easy for an enthusiast to crack (Hyundai all but said that was their intention with the 2.0L turbo Genesis Coupe.) These days, true enthusiasts modify cars for the love of it. People who just want to go fast or look good can just buy a car that does either (many of those cars are now quite old and very cheap!)
                    @fleetw00d - Hey thanks man. I was curious to what the exact part numbers were for those seals.
                    @deevergote - Yeah definitely! I would rather work on our 1990's Hondas than these new vehicles where parts are insanely expensive & more complicated.
                    Keep Pushing..
                      Note: Those aren't Honda part numbers for the seals, Honda only sells the FITV as an assembly (you can get the cover and cover o-ring separately).
                        Nice! A vietnamese troll bot
                          Why do they think that will be effective on an English-speaking site?
                          Deleted.
                            @fleetw00d Cool, thanks. Yeah I looked those O-Rings up. Just trying to figure where I should buy them from since they're all different sizes.
                            Keep Pushing..
                              Lol what?
                              Keep Pushing..
