SUSP: Front 5-lug Conversion
    Originally posted by JaK FRoSTWhiTE View Post
    They are .
    Jak we gotta talk....
    Originally posted by lordoja
      would the front spindle from this accord bolt up to the CB chassis? found one side in the junkyard but I didn't want to grab it because I wasn't sure if it fit
      2001 accord V6 coupe
      www.stl-imports.com
      Referral: crx08
      support the import community
        bringing this back from the dead...i've been reading this diy and the all prelude way and i have a few questions...
        i currently have the legend dual piston calipers along w/ 91 wagon trapped rotor (which is 1" in. bigger than sedans and coupes rotors) everything lines up perfectly and was pretty much a direct bolt-on. But, if I were to use ody RA front knuckles for a 5 lug conversion, what rotors would i need to fit the dual piston calipers? are the ody rotors the same size as the wagon rotors?
        Also, i read that the guys that went all prelude way, use a 5th gen accord dr's axle. is this also necessary when using the ody knuckles?
          Just picked up '96 Odyssey spindles today (knuckle, bearing, ABS sensor, hub). I'm ordering some Brembo cross drilled rotors to go with it and some hawk pads.
          I'm not sure which calipers I will be using with this set-up yet. Can I run the CB calipers with the T-25 bracket?
          The Lord watches over me!
          - D. Chappelle
            i used the 02 TL front knuckles complete from the j/y and found that my stock cb caliers fit the TL bracket nicely. i can't remember if it was a 25T bracket now.
            i removed the ABS sensor since I don't have ABS
            stayed drum in the rear just used CR-V drums with the prelude hubs
            and made the swap complete by getting the donut spare from an 06 TL so I don't get stuck with a flat
            can we get this thread stickied?
            http://i220.photobucket.com/albums/d...82408002-1.jpg
              Well, I just priced some rebuilt Nissin '96 Odyssey calipers with limited lifetime warranty. I'll be picking them up soon as I can get to the store. I'll also be running the Odyssey caliper bracket as well. Front 5-Lug conversion using all Odyssey parts FTW. Oh yeah, and I'm probably going to get the Energy bushing set as well.........Shopping for cheapest price as we type.........
              - D. Chappelle
                dc2 5 lug type r's rolling throught your brain????
                  hmmmm
                    This is the route i want to go. I found an 02 tl with just a broken stud on one side. I guess i dont need the caliper. Could you pm me the specifics on the rear. What year cr-v and hub? Which pads to use? Thanx
                    "Good judgement comes from experience,
                    alot of that comes from bad judgment"
                      Just some food for thought. The calipers of of other cars such as the TL, V6 Accord, or Odyssey have bigger calipers, and I also think the piston is slightly larger than the CB piston. I will double check when I have time to confirm.
                      Just as a reminder, those Legend coupe calipers are dual piston FTW!
                      - D. Chappelle
                        legend calipers are garbage, the numbers fro each calipers braking is diff since u have to mount them upside down from right to left n left to right just to get the bleeder, air will go upward and ur braking will suck, theres alot of research for it on honda tech.
                        the odessy calipers are good enough, they the same as the v6 accord, wagons and typer's
                        knowledge is everything with experience on hand then just hearing word of mouth doesnt prove you can do anything
                          Originally posted by BIEN_DIESEL View Post
                          ...the odessy calipers are good enough, they the same as the v6 accord, wagons and typer's
                          I know. That's what persuaded me to go with the Odyssey calipers. Now the question is, do I want my calipers and brackets to be black or red?
                          - D. Chappelle
                            I say red
                            Red Wagon DD - 1993 EX
                            http://www.cb7tuner.com/vbb/showthread.php?t=172734
                            Gray Wagon Project - 1992 LX
                            http://www.cb7tuner.com/vbb/showthread.php?t=166337
                              i have a question about this can we do the 5 lug for the rear using odyssey parts or do we have to use prelude parts
                                any body??? no???
