i have fogs and wiring might not stick em on tho not sure but they look nice
fogs!
Originally posted by 408cb7 View Posthow did you wire them with out the oem harness?
i need to wire mine but i dont know how to
its pretty simple.. one electrical wire from the +battery to the switch and a -battery to the switch and the +power from the switch to the lights and well the ground on the fogs went to the bots for my horns. in other words...i did it the cheep "ghetto" way lol my install was only 20 bucks.. all i bought was 16 gauge wire and connectors..and everything else i found in my garage
Nice pickup! So far I've found 5 sets of fogs at my local pick n' pull junkyard
92-93 x 2
90-91 x 3
Good job on the restore! Did you do anything about the tiny chip/crack on the lens itself? To keep moisture out, I would add some automotive Goop "the clear kind" and rub it on the cracks. This will create a seal and is semi permanent. (The goop can be pealed off with force like silicone if need be)
Just apply it inside the crack and rub off the extra. This will prevent bulbs from popping from too much moisture during rainy or cold days. It's almost like using the fix-a-windshield kit but for the fogs + it's cheaper.
I just recently found a 92-93 set thats in really bad rusty condition. The boots were missing and it let water damage the internal housings. I've been lazy to open them up to restore them and i'm thinking of making a custom EDM-style setup with them whenever I get free time.
I am the Yakuza CB7!JDM 96spec H22A 178HP 149TQ
"The JDM Fleet"
1993 Accord Sedan - 2.2 JDM H22a1994 Prelude V-Tec1999 CL 3.02000 Prelude2010 Accord Crosstour - 3.5
1993 Mirage S Sedan - 2.0 4G63 Project Evo 2.51994 Mirage S Sedan - 1.5
1991 Isuzu Impulse RS - 1.6 AWD Turbo1993 Asuna - 1.8 "CDM Impulse XS"
1993 Sentra SE-R - 2.0 SR20de1995 200sx SE-R - 2.0 Sr20ve
Originally posted by No Name13 View Postwell i cleaned up the lights today and installed them. heres how they look now.
Freedom Is Not Free
U.S Army 02/08 Medically Discharged
