not sure if i should post here or in electronic section?
but i think my fan timer is starting to have freegames, my fan (the one on the passenger side) stays on forever after i shut the engine every single time, and if i put the key on accessories it shuts off...it does that since i changed the motor a couple weeks ago, not sure if it could be related in any way?
every morning tho i get to the car, fan is off and i still have battery...untill yesterday...
so i checked the basic stuff, its not the fan switch because when i unplug it, the fan doesnt stop, its not my relay because when i swap it with the electric windows relay the fan dont stop either...so that leaves the fan timer
today i removed it (what a pain in the a$$) and opened up the module, i was hoping maybe it could be a simple fix like the DRL module (just reweld some cracked weldings and your good to go) but none of the weldings seem to have any visible damage...
so i figured, if the fan stays on, maybe its because one of the little ''things'' (transistors? capacitors? resistors? switches? no idea what they are, i suck at electricity stuff) welded on the board is broken and gives continious electrical current or something? so im wondering if there is any way to diagnose wich one if the faulty one? because i can get those little ''things'' for like..50 cents at a store nearby and welding a new one on would be a simple fix, because i dont want to buy a new module from honda and swapping for one from the JY i know for sure the problem will happen again eventually...
i will get a used one in the meantime but id really like to find a way to literally fix the module, has anyone done it before?
