Old 05-13-2018, 01:15 PM   #1
ukemike
ukemike is cool... so far.
Weight of an f22 engine
What does an f22 engine weigh with all but the exhaust on it? I'm going to buy an engine stand for that purpose and need to get the right one without over-spending.
1993 Accord Lemons Race Car, "Green"
M2A4 Trans, Cusco 1-way Limited Slip Differential, Stage 2 Clutch and 11lb flywheel.
A4 Header, 2" exhaust all the way back, catalyst delete, glasspack muffler, PT12 ECU.
ukemike is offline   Reply With Quote
Old 05-13-2018, 03:31 PM   #2
Jarrett
For what you're wanting to do, you can get the cheapest engine stand Harbor Freight sells. The engine is in the neighborhood of 400lbs when fully dressed. I think the one with four casters is a little nicer while not being much more expensive.
Either way, Harbor Freight for something like this all day long.
Old 05-14-2018, 01:47 AM   #3
ukemike
Yup. That's the plan. Just wasn't sure I could get the smallest one. Thanks.
Old 05-14-2018, 04:33 PM   #4
steelbluesleepR
I shoot people
steelbluesleepR seems to have made some friends!
those things are usually designed for small block chevys and the like, and there's not much lighter than an all-aluminum 4cyl. you're good with just about anything.
Originally Posted by Stephen Fry
steelbluesleepR is offline   Reply With Quote
Old 05-17-2018, 11:17 AM   #5
Size9zombie
Size9zombie is cool... so far.
Yep, I have a 350, a 383, and a 2 bolt 400 sbc at home, all on harbor freight stands. They are tough.
Size9zombie is offline   Reply With Quote
