I am replacing my oem trunk with a carbon fiber oem style trunk. I can to realize is that I need to remove the two tension bars that make the trunk pop open. Doe everyone and a special and/or easy way of removing them with hurting my self? I believe there is special tool from Honda but don't know the name for it so I would not know what to search for. Any help greatly appreciate in advance.
Removing trunk springs
i have never removed those, but everytime i need to remove a part that im scared it will pop in my face and explode my head, i attach it with metal wire or with a ''C'' clamp visegrip and wear gloves to avoid getting my fingers snapped, then i grow myself a pair of huge balls of steel and just go ahead doing the job lol
easiest way would be bolt cutters, standing as far away as you can.
Originally posted by Stephen Fry'It's now very common to hear people say, "I'm rather offended by that", as if that gives them certain rights. It's no more than a whine. It has no meaning, it has no purpose, it has no reason to be respected as a phrase. "I'm offended by that." Well, so fucking what?' —Stephen Fry
Originally posted by sonikaccord View PostRemove it when the trunk is closed so there is not as much tension on it.
Edit: Be sure to support the trunk lid, as soon as you undo one spring, the second spring probably isn't enough to hold it up.Last edited by Fleetw00d; 01-19-2014, 10:52 AM.90 LX 4dr 5 spd 396,014 (sold 1/1/2022) - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=201450
Why can you not just remove the lid from the hinges? Spoiler or not, the CF trunk will be lighter so it will spring up a little more than the stock trunk but it shouldnt be an issue.
Originally posted by JarrettIs there a goal you're trying to accomplish besides looking dope as hell?
Originally posted by MikeW View PostWhy can you not just remove the lid from the hinges? Spoiler or not, the CF trunk will be lighter so it will spring up a little more than the stock trunk but it shouldnt be an issue.
Or another thought, maybe the carbon fiber isn't strong enough to hold the tension of the springs.
Originally posted by fleetw00d View PostThere is more tension on them when the trunk is closed. I have used a large pair of channel locks to grab the end of the "U" and the side of the tool as the fulcrum to undo/and reinstall the springs (still be careful!).
Originally posted by dcsally97 View PostThere is a YouTube video on this. I did the same thing when I installed an OEM spoiler. I used vice grips instead of channel locks as fleetwood stated above.
So i just remove them so it would not have a chance of breaking. Its already done and finish.
Originally posted by Corweena View PostThat's what I was thinking. Unless the trunk doesn't have mount points for the springs.
