I have a 1992 honda accord EX but the engines blown, can I take a 1992 honda accord 4 door engine and drop it in with out any trouble? also what would be the easiest route to take to install new rotors? I know there sealed on or whatever but the mechanic I went to told me 500 a wheel:O and thats just labor!
A couple questions..
research my friend..theres plenty of threads
Members' Ride Thread :http://www.cb7tuner.com/vbb/showthre...82#post2939682
My CB7 Tribute Vid..https://www.youtube.com/watch?v=XqWFstSzLH8
Track ready EK..https://www.youtube.com/watch?v=IoYKsoL0i7M
Yes you can swap the motor with no problem if you know what you are doing. As for 500 a wheel thats just damn stupid that means it will be 2000 for the whole car and with that u can buy a new one. the idle surge is the idle air control valve most of the time but if you plan on swapping the motor you do not have to change it since your motor should come with one. As for your car not starting at random times can be several things not just one in particular.
btw Searching is a very easy way to find this out all by yourself if you would take the time to do it. And your mechanic is trying to juice you for that price of doing rotors. i would recommend getting a new one
As far as your car randomly not starting. It could be a faulty Main Relay, since it a fairly common problem on old hondas. Though, the main relay problem is mostly seen when your car is sits on the sun for too long on a hot day or if its really cold.
As for as the idle problem, it could be a Vacuum leak(meaning that there could be an air leak on your intake)... or maybe a bad Fast idle thermo valve.
You can see the diagnosis for that here:
http://tennesseecrxgroup.com/HOWTOS/FITV.pdfAccord 93 LX: H23 intake mani, Ebay short ram, P12 ecu, Full exhaust. Lots of noise... and that's about it, just noise. LOL
Mazdapeed MX-5 04: Begi Intake, Forge BOV, Ebay FMIC. Whoooooooosh... Phhhff!
I know that me and my friend tried and we couldnt figure it out:|
but thanks man you've been alot of help though.
even though this is prolly everywhere on the site...
where can I buy a new engine for it? should I consider ebay?
i cant find anything locally... I want a rebuilt one, that would be great..
