foglight wiring
This is a sticky topic.
    ^ i'm using these harnes but with the OEM switch and fogs..
      I have a question. You used 16 guage wire right throughout the install right? Where did you mount the relay under the hood so that it is not prone to heat/moisture? And how do you tap into the pins in the fusebox under the driver's side? Do I just shove the wire in under the fuses? Thx
        Fog Switch
        How is the switch for the ebay kit? I understand that you used the OEM switch cause you had it but is the other (ebay) switch like the OEM switch? Will it fit in the same spot and work the same? That is all I care about for now.
        I My Honda
        Check out my Ride Here
        09-11-01 NEVER FORGET
          EDIT, all fixed, OEM harness installed. Works like a dream!!
            Originally posted by ap716
            could i use the harness and switch from this kit?
            if you buy that and use just the harness, ill buy the actual lenses off you.
              i have it(fog lights only- brand new).. just have to dig it out from the garage if you want it..
                fog switch from the ebay kit are cheaply made. only lasted for a few months. Ebay switch will fit in the same spot as with the OEMs and are functionaly the same but not in terms of durability.
                  jdm h22a CD8 FOGLIGHTS
                  i JUST PURCHASED CD8 H22A YELLOW FOGLIGHTS WITH SWITCH, DOES ANYONE KNOW WHAT THE DIFFERENT COLOR WIRE ARE FOR?
                  2 bLACK THAT SHOULD BE GROUND, ONE RED WITH YELLOW STRIP THAT SHOULD BE POWER, AND 2 RED WITH BLACK LINE? no clue ANY IDEAS!
                  "never underestimate the Driving skills of the HANDICAPP" By: Myself....
                    anyone have any ideas about the fog lights ? i appreciate it
                      i just used the fog light kit from a 94-95 for the harness and the switch as my switch did not have the plug in the back of the switch so i used the switch too,seems to be working fine the harness works great came with relay and everything but the connector is different from my jdm foglight switch.
                      im finally back in a cb7 its like coming home.lol
                      93 ex accord coupe h22 SOLD
                      90 ex accord 4 door SOLD
                      91 se accord 4 door SOLD
                      92 lx accord coupe SOLD
                      93 ex accord 4 door SOLD
                      92 ex accord 4 door h22 SOLD
                      93 ex accord 4 door auto SOLD
                      92 ex accord coupe auto
                        Fog Lights
                        Where Did You Get The Harness From? Thanks For The Help
                          here you go.. let me know if your interested..
                          http://www.cb7tuner.com/vbb/showthread.php?t=40957
                            has anyone answered the question of all the wiring colors on the foglights? i'm still confused to why the 2 wires from the fogs spead out to 5 then go back to 2 again going to the other fog. since my harness was cut idk wat to do. i bought an aftermarket wiring kit but i can't match the 2 up to make my fogs work..
                              My Edm harness goes: 2 wires from each fog(1 blue/red stripe) and (1 black) the black forms into 1 ground.Then I have the blue/red striped that goes to the rest of my harness that goes through the firewall into the car. which has two plug-ins that go underneith of the dash and then that goes to the switch.
                              I could take pics of it if need be.
                                yeh that'd be great.
