i was wondering since a h23 im goes on f22 not much fab woulda a aftermarket h23 intake mani go on f22 like skunk 2 im, obx im??
aftermarket h23 im
aftermarket h23 im
http://www.cb7tuner.com/vbb/showthread.php?t=138029 <-mrt
diy whore riiittteeee here
[URL="http://www.cb7tuner.com/vbb/showthread.php?p=2208455"]
http://www.b20vtec.com/forums/members/pr3pg4lyfe.html
Are there aftermarket H23 manifolds? If so, yes, they will bolt on just fine. I don't know for sure if the Prelude has more clearance between the head and firewall than the CB7, so you might want to make sure that any other manifold you find doesn't go back further than the CB7's bay can accommodate.
yup there is
http://cgi.ebay.com/ebaymotors/OBX-I...Q5fAccessories
i thought there was a skunk 2 somewhere i cant find it tho.http://www.cb7tuner.com/vbb/showthread.php?t=138029 <-mrt
There wasn't a Skunk2 one the last I checked, but it's been a while. That OBX one is a Venom knockoff, so there may be a Venom manifold out there as well.
OBX isn't amazing, but the design of that manifold is simple enough... and the price is right... it might be worth cheking into. It doesn't LOOK like it won't fit.
I'd make sure you can use your stock throttle body as well. It says all stock sensors and auxiliaries can be used, so I assume that means the throttle body... but be careful. I know the Skunk2 manifold for the H22 won't take the stock H22 throttle body. That will increase your cost considerably if you have to buy a new TB!
ok thanks for the infohttp://www.cb7tuner.com/vbb/showthread.php?t=138029 <-mrt
